2003 Ford escape 3.0L negative LTFT while idling
- ZisDead
3 years 8 months ago #60344
by ZisDead
2003 Ford escape 3.0L negative LTFT while idling was created by ZisDead
Hi everyone, i have negative long term fuel trims (around -10%) for both banks while idling and while running with the foot off the pedal. While driving normally ltft and stft are in normal ranges. No DTCs present, O2 sensor readings seem ok. Any suggestions?
Thank you
Thank you
- boostedsil40
3 years 7 months ago - 3 years 7 months ago #60382
by boostedsil40
Replied by boostedsil40 on topic 2003 Ford escape 3.0L negative LTFT while idling
so running a little rich only at idle,i wonder if fuel pressure regulator diaphram has small leak?does this vehicle use pressure regulator that has a vacuum line to it?
maybe try looking at your fuel trims and pinching the evap line and see if fuel trims go normal
Last edit: 3 years 7 months ago by boostedsil40.
- ZisDead
3 years 7 months ago #60387
by ZisDead
Replied by ZisDead on topic 2003 Ford escape 3.0L negative LTFT while idling
Yes indeed it has a pulsation damper (this is a returnless system vehicle, so i guess the regulator is with the fuel pump) which is connected to the vacuum line. Disconnected the vacuum, no visible leaks or traces of fuel. When you say pinching tha evap line you mean the hose from the intake to the purge valve?
Thank you
Thank you
3 years 7 months ago #60404
Replied by Noah on topic 2003 Ford escape 3.0L negative LTFT while idling
Are you talking LTFT, STFT, total trim?
To perfectly honest, if the computer isn't concerned enough to set any trouble codes, I wouldn't spend any time or money on it.
- ZisDead
3 years 7 months ago - 3 years 7 months ago #60415
by ZisDead
I am talking about LTFT. STFT is oscillating around zero between approx -3% to 3%
Last edit: 3 years 7 months ago by ZisDead.
3 years 7 months ago #60426
Unless there is a running complaint or engine light, I wouldn't go chasing it at this point beyond maybe an oil change and keep alive memory rest.
It's possible for fuel contaminated oil to cause richer than normal trims via the pcv system. You can try cleaning the MAF to see if there's an improvement, or as boosted suggested, isolating the evap system, but like I said, if this came to me, I would probably ship it and move on to next car until there is a more tangible issue.
- ZisDead
3 years 7 months ago #60433
by ZisDead
Ok, thank you, i will try boosted and your suggestions and see if i get to any conclusion
Thanx again
Thanx again
