9 Brake codes (ABS wheel speed sensor ground problem)
  • JohnJas
  • JohnJas's Avatar Topic Author
3 years 7 months ago - 3 years 7 months ago #60481 by JohnJas
Hi Scanner Danner,
I have a VW Golf mk6 cayc with the same type of sensor Magneto resistive, I have identified it with the help of this video.
My problem is I have battery voltage and signal on the same wire for both left/right wheel speed sensors but no ground feed to my Front Right speed sensor but i do for the Front Left.
I did a continuety test from the right sensors ground pin to the abs module connector and continuety was ok. Which lead me to think it was a computer issue. The only evidence I have is that the car has had a rat infestation but cannot see any damage on the surface.
I am getting various codes showing which are 01279(longitunidal acceleration sensor adaptation), 01435 (brake pressure sensor 1 adaptation), 00778(steering angle sensor adaptation), 01423(lateral acceleration sensor)
But my main concerns are= 01314 (engine control module read trouble codes - intermittent), 00285/00283 (left/right wheel speed sensors G45 electrical problem intermittent), 00668 (supply voltage terminal 30 upper/lower limit reached - intermittent) and finally 01305(databus for infotainment - no signal/no communication)
Is there any advice you can give me please? Just seems like a coincidence that it is the left/right front wheel speed sensors acting up and not the rear as they where the only sensors i was previously experimenting on trying out my new ocilloscope checking for signals lol.
Reply
Last edit: 3 years 7 months ago by JohnJas.
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
3 years 7 months ago - 3 years 7 months ago #60485 by ScannerDanner
Replied by ScannerDanner on topic 9 Brake codes (ABS wheel speed sensor ground problem)
Were there images you were trying to add? Are you still not able to?
Maximum file size is 5mb I think per image?
Don't be a parts changer!
Last edit: 3 years 7 months ago by ScannerDanner.
