12 to 19 ford dual clutch systems
- bizz2222
3 years 7 months ago #60493
by bizz2222
12 to 19 ford dual clutch systems was created by bizz2222
Just want to see how many ford mechanics are here, my question is can the 11 to 19 6 speed automatic dual clutch system have forward gears and no reverse and the dual clutch be bad ? Most of the time if the car has forward or reverse it is usually 1 of the 2 clutch forks or the tcm or 1 of the 2 silanoids correct me if I'm wrong but there is only 1 clutch disk I the pressure plates right ? Would be good to know this answer. Thank you for any help
- kkane97.kane
- Thank you received: 6
3 years 7 months ago #60624
by kkane97.kane
Replied by kkane97.kane on topic 12 to 19 ford dual clutch systems
Clutch a gears 1 3 5
Clutch b gears 2 4 6 r
I do about one a week lately, Luk 07233 kit same as OEM. Bring it in, perform clutch relearn procedure, listen closely while it is actuating and most times you can hear when it has a bad throw out bearing or broken fork.
Using the measurements given after completing the clutch relearn helps determine clutch wear.
The following user(s) said Thank You: Noah, Tyler, bizz2222
- kkane97.kane
3 years 7 months ago #60625
by kkane97.kane
This is a good resource to identify how they work, there are two clutches inside the bell housing as far as your original question
www.google.com/url?sa=t&source=web&rct=j...7gT8Io5pdx0xxc6TiKzF
The following user(s) said Thank You: Noah, Tyler, juergen.scholl
3 years 7 months ago #60645
Thanks for that link!
And for that bit about using the relearn procedure to check for wear.
Have you ever inadvertently created a problem by running the relearn? As in, car came in shifting fine with no codes, but running the relearn exposed a problem. Do you have some known good measurements? There's still a ton of these things running around where I work. :lol:
Replied by Tyler on topic 12 to 19 ford dual clutch systems
- kkane97.kane
3 years 7 months ago #60646
by kkane97.kane
This is a good resource that will answer that for you. Absolutely I have seen an issue caused during a adaptive test. I typically warn the customer it may help their concern it may make it worse, but is a necessary step to diagnose what the issue is
