2009 traverse Ltz crank no start
  • Cheryl
  • Cheryl's Avatar Topic Author
3 years 7 months ago #60496 by Cheryl
2009 traverse Ltz crank no start was created by Cheryl
Does anyone have a known good cam crank relationship? I’m coming up with something weird doing my checks at the pcm and checking bank 1 I’m getting looks like the exact signal for the cam and intake cam. I overlaid them in my scope. I’m thinking they’re shorted together? Has anyone run across this? Getting all 4 cam sensor codes have 5 volt ref and grounds to them all.
3 years 7 months ago - 3 years 7 months ago #60507 by juergen.scholl
Replied by juergen.scholl on topic 2009 traverse Ltz crank no start
Last edit: 3 years 7 months ago by juergen.scholl.
  • Cheryl
3 years 7 months ago #60509 by Cheryl
Replied by Cheryl on topic 2009 traverse Ltz crank no start
I seen it doesn’t label what bank it is or intake vs exhaust cam
3 years 7 months ago - 3 years 7 months ago #60510 by juergen.scholl
L
It states bank one and shows milage....
Also check the related tab, there are more hidden captures. A total of four. Probably you'll find the original waveform with the author's complete notes in the pico library. Do you have access to it? Otherwise I could have a look later.
  • Cheryl
3 years 7 months ago - 3 years 7 months ago #60511 by Cheryl
This is a relative compression test set on ac voltage 1 volt leads reversed positive at negative post negative at positive post directly at the battery.
Last edit: 3 years 7 months ago by Cheryl.
  • Cheryl
3 years 7 months ago #60512 by Cheryl
Added attachments at the beginning of the post let me know what you think
3 years 7 months ago #60513 by juergen.scholl
I think you (only) can tell there is abnormality. NOT MORE. Now its part to of the diagnostic process to determine the root cause.
It catches the eye that the higher voltage drops happen on companion cylinders, so you may have two cylinders high and not four low...
You may also try a voltage drop RC test from engine block t battery negative post. This allows for ec volts in the mV range without inversion. Put a sync as well for cylinder id.
  • Cheryl
3 years 7 months ago #60515 by Cheryl
I thought I seen a Scannerdanner video hooking the leads up backwards so it’s like a relative compression test with an amp clamp. So you wouldn’t need to invert it. But customer said if it’s internal then he isn’t going no further he thought it was a fuel pump issue
