2009 MINI Cooper N12 engine P0420
3 years 7 months ago #60533 by SK
Subject vehicle downstream O2 sensor is switching as it should without delays; I tested it while driving and watched the downstream O2 go full rich at WOT, and full lean when decelerating. I performed my first O2 storage test as Paul outlined in Chapter 5, but according to the test I just performed, the cat is good; I have a 6 second delay when I shut off the propane before the O2 drops lean again (.2 volts).
So, why does the PCM keep kicking the P0420 code?
