I'm at wits end.
9 years 5 months ago - 9 years 5 months ago #9689 by Chad
Replied by Chad on topic Pictures
Your observation of the marks being off by less than a tooth is correct. It has not "Jumped" time. A stretched chain will cause all valve openings and closings to be, slightly, retarded. This can cause a the rough idle. That being said, based on the cranking video, I would jump straight to the number four cylinder and check compression. I am imagining a scenario of an over heating bearing, splashed with some oil, would cause your burning smell. As Noah stated, the cam can snap. I have seen snapped cams, right at a bearing, due to clogged oil passages (severely neglected oil changes/sludge) If it did snap, cylinders after the break will shown by compression.
Last edit: 9 years 5 months ago by Chad.
The following user(s) said Thank You: JeremyS10
9 years 5 months ago #9691 by toadyboy1957
Replied by toadyboy1957 on topic Pictures
i do a compression test on every vehicle i touch ive been a DIYER for over 40 years it lets customers know the condition of their engine and where potential problems are
9 years 5 months ago #9693 by toadyboy1957
JeremyS10 wrote: Any suggestions on the timing chain and gears? I got the tensioner from GM. I've read in multiple places not to mess around with that, and get OEM. But aftermarket chains and sprockets are ok. I've heard horror stories.anoit Cloyes, and I don't know anything about Sealed Power, or Melling. Are they good quality?
Sealed power is extremely good quality products
  • JeremyS10
  • JeremyS10's Avatar Topic Author
9 years 5 months ago #9695 by JeremyS10
Replied by JeremyS10 on topic I'm at wits end.
I went to AutoZone and O'Reily this evening, they're out of stock on everything. I'm gonna have to order them, so they'll be in likely mid next week. I'm going to put it back together, and the compression test will immediately follow. I will post the results as soon as I have them. Thank you for the help guys.
9 years 5 months ago #9703 by Chad
Replied by Chad on topic I'm at wits end.
Just a side note. Depending on the oil cap location, you might be able to look inside and see if the cam is turning, or not, without taking anything apart.
  • JeremyS10
9 years 5 months ago #9707 by JeremyS10
On this truck you add oil to the same tube the dipstick goes in. It's a small tube that comes up from the back of the motor, and gets bigger at the top for the cap to attach to, and the dipstick is attached to the cap.
9 years 5 months ago #9710 by Ben
Replied by Ben on topic I'm at wits end.
I would go ahead with the compression test with the stock gears and chain. It hasn't jumped time . I kind of suspicion a broken cam from the sound of that cranking video in which case it would be a waste to change gears and chain. Unless I am mistaken you should be able to take that compression test even with the timing cover off of the engine start at the back cylinder if it dont have compression or compression Is very low them go ahead and pull valve cover but I wouldn't put more parts in it till you have found problem . You may be replacing the motor if there's to much damage.... but that's all speculation compression test first!
  • JeremyS10
9 years 5 months ago #9712 by JeremyS10
If I can do the compression test with the timing cover off, I will.
9 years 5 months ago #9714 by Noah
Replied by Noah on topic I'm at wits end.
Wow, this thread really took off!
I went back to the begining and checked out those pics again.
Pole is right, those marks aren't as far off as I thought they were when I first read this on my phone.
I'm really interested to know what the compression test results reveal!
  • JeremyS10
9 years 5 months ago #9715 by JeremyS10
I will be doing the test today after work, and I will post the results as soon as I finish. Thank you all for your help.
  • JeremyS10
9 years 5 months ago - 9 years 5 months ago #9724 by JeremyS10
Ok, compression test done on cylinder 1 and 2. Number 1 reads 70 psi. Number 2 reads 30 psi. I don't think doing 3 and 4 is really necessary, as I think 1 and 2 tell me enough. If I need to, I will, but my battery is dead, and number 4 I don't think I can even get to. Also, number 2 didn't read anything for about 5 seconds of cranking. Finally went to 30.
Last edit: 9 years 5 months ago by JeremyS10.
  • JeremyS10
9 years 5 months ago - 9 years 5 months ago #9725 by JeremyS10
How does this spark plug look to you guys? It has maybe 2000 miles on it. It's about 5 months old, and I pretty much just drive to work and back, which is about 20 miles round trip.
  • JeremyS10
9 years 5 months ago - 9 years 5 months ago #9726 by JeremyS10
Ok I did number 3, and it reads 40 psi. Number 4 reads 50 psi.
9 years 5 months ago #9751 by Noah
Replied by Noah on topic Pictures
Yikes! Something terrible happened in there for sure.
Here's the video I mentioned before showing how to perform a cylinder leakdown test.
If you have an air compressor, you may be able to rent the leakdown tester tool at a local auto parts store.
Of course, if you don't want to sink any more money into this engine, then there's really no need to do the test.
  • JeremyS10
9 years 5 months ago #9755 by JeremyS10
Replied by JeremyS10 on topic Pictures
I don't have an air compressor. And test after test seems to yield no results, just gets me closer to the next test. I watched a video about leak down testing, and the guy said if it's in the top end, repair, if it's in the bottom, replace. Since I still have no idea what's wrong, and I've done all the tests I can, I guess that's a wrap.
9 years 5 months ago #9756 by Chad
After all you've been through, I would be interested in having a peek under the valve cover. Watch things move, or more to the point, NOT move. THEN call it a wrap.
9 years 5 months ago #9757 by Noah
pole71 wrote: After all you've been through, I would be interested in having a peek under the valve cover. Watch things move, or more to the point, NOT move. THEN call it a wrap.
+1!
  • JeremyS10
9 years 5 months ago #9760 by JeremyS10
Yeah, I might as well. Since I'm gonna have to replace the motor I'm sure, why not take it apart and see exactly what's wrong, if I can. Thank you guys for your help. I appreciate it. I will update you on what I find.
9 years 3 months ago #10873 by Rockyroad
Replied by Rockyroad on topic I'm at wits end.
What a buzz kill, like closing my eyes at the scary parts. All the way to the point of calamity without conformation. At this point the story can still go the other way and have a happy ending. Maybe compression was low from cylinder wash from all the cranking. Or maybe I just prefer happy endings
Someday I'll figure this out
  • JeremyS10
9 years 3 months ago #10925 by JeremyS10
No happy ending. The truck is sitting there, rotting away. 3 grand worth of new parts, useless. I'm probably going to tow it to the warehouse I work at, and part it out. Or not. At this point, I really don't care. Kinda just want it gone. I figured my HOA would've had it towed out of here by now. But nope, there it sits.
Time to create page: 0.454 seconds
