1996 Ford F 150 4.9 L6
- toadyboy1957
"both front and rear fuel pumps"
I assume this is a dual tank truck? I have never had to work on a dual tank system but, my first question would be is the fuel being pumped from tank to tank due to a bad check valve, or something? Do both pumps run at the same time, at any point in the tank switching processs? What kind of stream would you have, running both pumps at the same time?
- toadyboy1957
toadyboy1957 wrote: if there was a bad ground would it cause the new pump not to pump correctly or would it not pump at all
Yes.
I'm not sure of the "plumbing" between the two tanks but, make sure pressure is not bleeding off to the auxiliary tank. Make sure the fuel has no place to go except the fuel-rail. If pressure is not being bled off to the auxiliary tank, and you have no leaks, and you have verified GOOD power and ground,...you have to question the fuel pump. NEW stands for Never Ever Worked.
- toadyboy1957
- toadyboy1957
- toadyboy1957
- toadyboy1957
- toadyboy1957
- toadyboy1957
A google search brought me to this thread on another forum.
stop-the-star-program.3084.x6.nabble.com...iming-td5027709.html
Just check timing on a 93 Ford F 150 4.9L V6. Now theres two places to check the timing one from driver side and one from passenger side, both sides have timing marks. Which side is the correct side to check the timing? I went with the ones on the passenger side.
The passenger side is correct. Pull the SPOUT and check that it's 10° BTDC. That engine family has been around since the mid-to-late sixties, and the driver's side pointer is obsolete and unused since the mid-seventies.
- toadyboy1957
- toadyboy1957
- toadyboy1957
- toadyboy1957
