P0228D and P0089
- yoroberg
3 years 6 months ago #61040
by yoroberg
P0228D and P0089 was created by yoroberg
I have a problem with a Chevrolet Equinox 2013, The code set on the scanner
P0228D and P0089
With reduced engine Power. + stabilitrak
I already replaced
Throttle body
Fuel rail sensor
Camshaft position sensor
same issue
Any help, please?
P0228D and P0089
I already replaced
Throttle body
Fuel rail sensor
same issue
Any help, please?
- matt.white
- Thank you received: 29
3 years 6 months ago #61047
by matt.white
Replied by matt.white on topic P0228D and P0089
- yoroberg
3 years 6 months ago #61050
by yoroberg
Replied by yoroberg on topic P0228D and P0089
Hi
No. I checked with the GMC recall website.
Thanks
Berg
Thanks
Berg
- George Uk
- Thank you received: 6
3 years 6 months ago #61053
by George Uk
Replied by George Uk on topic P0228D and P0089
You really need to stop replacing parts and diagnose this correctly - Replacing parts without evidence of failure can make it harder to fix !!
P0228D Is an Accelerator PEDAL fault - Not Throttle Body !!
and P0089 is a Fuel Pressure Regulation fault.
You would benefit from looking at the Freeze Frame Data for those faults and then the Data Pids.
With a wiring diagram, the next step would be to hook up a scope and determine the cause.
