Alternator not charging
- A7Guy
3 years 6 months ago #61061
by A7Guy
Alternator not charging was created by A7Guy
2012 Audi A7 3.0t had a alternator not charging battery warning . Replaced battery and alternator and still not charging. P1B0100 alternator electrical fault
- juergen.scholl
- Active partschanger
- Thank you received: 462
3 years 6 months ago #61070
by juergen.scholl
Replied by juergen.scholl on topic Alternator not charging
Did you put a new alternator on? Many rebuilts are bad out of the box... Did you also put a new one way clutch pulley on and/or checked the old one?
If this is the typical bosch unit it will probably have 3 connections: B+, L and DFM. Have you verified wire integrity?
- George Uk
- Thank you received: 6
3 years 6 months ago #61071
by George Uk
Absolutely agree !!
Just last week I had a Ford Fiesta (Petrol 2009) with a charging fault, SMART CHARGE using a PWM signal for communication with ECU.
With a scope I proved that the ECU & Wiring was fine but the Signal was being corrupted / pulled down by the Alternator. Also tapping the alternator with a hammer would bring it back to life for a while.
Bought a "NEW" unit £240.00 - Same - Not charging.
Got the original tested and rebuilt by a trusted friend - same - Not Charging - £100.00
Got one from Ebay £ 30.00 - Fixed and gone.
Very Nearly put an ECU on it :dry:
Replied by George Uk on topic Alternator not charging
Absolutely agree !!
- A7Guy
3 years 6 months ago #61074
by A7Guy
Replied by A7Guy on topic Alternator not charging
Yes I did put a brand new hitachi alternator on it. Where’s the one way pulley located?
- juergen.scholl
3 years 6 months ago - 3 years 6 months ago #61075
by juergen.scholl
The one way clutch is integrated within the pulley that drives the alternator via the belt.
Last edit: 3 years 6 months ago by juergen.scholl.
- A7Guy
3 years 6 months ago #61076
by A7Guy
Well it is a brand new alternator so the pulley is brand new also . Where else can I check?
3 years 6 months ago #61086
Replied by Tyler on topic Alternator not charging
Voltage drop the B+ cable and the alternator case. If I remember right, I think the main block ground cable comes off when you replace this alternator.
I *think* the single wire field connection is a LIN with the battery module. If you disconnect the field connector, does the alternator start charging? With the connector unplugged and the key on, what voltage do you find at the violet/white wire?
If the B+ and alternator case don't have excessive voltage drops, and the LIN is good all the way out to the alternator, and the belt isn't slipping, then the alternator has everything it needs to work. Get another alternator.
- A7Guy
3 years 6 months ago #61090
by A7Guy
How do I know if the belt is slipping?
- A7Guy
3 years 6 months ago #61091
by A7Guy
Violet and white wire? The lin ?
Time to create page: 0.250 seconds
