2009 Chrysler 300 touring 3.5
  • Cheryl
  • Cheryl's Avatar Topic Author
3 years 6 months ago #61291 by Cheryl
2009 Chrysler 300 touring 3.5 was created by Cheryl
Having a traction control light that comes on cuts the power to the throttle no codes. Speed sensors steering angle sensor looks good. Thinking I might have an alternator issue. Does this look like a bad diode in the picture I attached
3 years 6 months ago #61292 by Tyler
Replied by Tyler on topic 2009 Chrysler 300 touring 3.5
Don't think so. That looks more like secondary ignition interference, IMO.
  • Cheryl
3 years 6 months ago #61293 by Cheryl
Replied by Cheryl on topic 2009 Chrysler 300 touring 3.5
From a coil? You think that can spike the alternator?
  • Cheryl
3 years 6 months ago #61294 by Cheryl
Only reason I went down the alternator was because if I unplug the alternator the issue goes away
3 years 6 months ago #61296 by Tyler
Nah, I just mean your scope leads probably picked up on some RFI from the coils.
Well isn't that interesting. :huh: The alternator ripple honestly didn't look excessive... I wonder if it's the low system voltage that's preventing the issue from happening.
  • Cheryl
3 years 6 months ago #61298 by Cheryl
System voltage stays at 14.4 even with alternator plugged in. Had a spare tire on it thought maybe it was the issue replaced with correct size tire still does it.
3 years 6 months ago #61299 by juergen.scholl
Replied by juergen.scholl on topic 2009 Chrysler 300 touring 3.5
On a longer time base is there a repetitive pattern when that spike occurs?
As Tyler I don't think the ripple is an issue at this point. (I believe he meant with the alternator unplugged/not charging the then low system voltage may impede the issue to happen.)
Btw, how did you set up your scope? It seems to be configured at DC voltage??
  • Cheryl
3 years 6 months ago #61301 by Cheryl
Yes it’s repetitive on a longer time base. I have the scope ac coupled on a 1 volt scale I’ve run it on a 500 ms time base that drop is repeatable.
  • Cheryl
3 years 6 months ago #61302 by Cheryl
Only thing I noticed is there is 2 readings for each wheel. One is in mph and other rpm. The mph are all the same all 4 wheels but the rpm is different from the left rear wheel. No codes in any module
3 years 6 months ago #61303 by juergen.scholl
You may want to scope the questionable wheel speed sensor directly and compare to another one.
  • Cheryl
3 years 6 months ago #61305 by Cheryl
Will do and let you know I’ll post pictures
3 years 6 months ago #61306 by Matt T
Replied by Matt T on topic 2009 Chrysler 300 touring 3.5
For it to be the alternator rectifier you're looking for the problem to happen at a repeatable number of waveform humps, with every sixth hump being the most common. If it's engine noise, or load, related it'll be a repeatable time which corresponds to engine rpm. For example noise from a COP coil will show every 200mS at 600rpm.
  • Cheryl
3 years 6 months ago #61330 by Cheryl
It’s repetitive. Zoomed out it has the drip same exact spot on a longer time base
Time to create page: 0.351 seconds
