2015 gmc yukon
  • GaryJP
  • GaryJP's Avatar Topic Author
3 years 5 months ago #61401 by GaryJP
2015 gmc yukon was created by GaryJP
Having an issue for code p0340.You would think an easy diag.Have 5 volt ref. and no voltage drop on lo ref.Issue comes to light when disconnecting sensor and having issue with drop down voltage between 4.2 and 4.5 volts and struggles to reach good square wave on lab scope clipped on way up.voltage dropped all ground and power circuits to pcm ok. sent computer out for repair and was told proccesor was n/g.had them replace and ship back to us.before starting engine with reman pcm i checked drop down voltage and was at 4.98 volts.everything was fine till engine warmed up and code set for p0340 and rpm signal for cam sensor stopped working and dis connect voltage was 4.2 volts at drop down circuit.been thru 2 computers.only thing done mechanically is new cam and lifter dod deleted.
Thanks Gary
  • ScannerDanner
  • ScannerDanner's Avatar
  • Administrator
  • Administrator
3 years 5 months ago #61412 by ScannerDanner
Replied by ScannerDanner on topic 2015 gmc yukon
I need an interpreter. Please type in complete sentences and provide images of what you are referring to. This is why you've not received any replies
Don't be a parts changer!
