Throuttle daignostic
  • A93320336@gmail.com
  • A93320336@gmail.com's Avatar Topic Author
3 years 5 months ago #61415 by A93320336@gmail.com
Throuttle daignostic was created by A93320336@gmail.com
Dear team
I have 2011 ford turuse 3.5
Code p2107 and p2110
We replace the throttel staill same code the 5ref and the ground and 2 wire signal is reading ok
I scope the 2 signal it show with in the range 4 and 1.2
I check the wire from thouttle to pcm it is ok
How to check if its the throttel or the pcm
It show 2 volt in each motor wire
The code id hard code not clear
The problem after thy clean from inside
I need to learn how to dagnostic the thorttel motor
Time to create page: 0.258 seconds
