Anyone with BMW knowledge on AC strategies?
- JoesAutoElectric
"The man who says it cannot be done should not interrupt the man doing it."
- Chriscoy
- Heavy duty truck technician / foreman/ parts guy/
- Thank you received: 6
I could possibly see a protection strategy there to prevent over pressure.
I'd verify the fan is faulty and get it swapped out on principle, but inform the folks it may not be the root cause. Gotta fix what's broke first, Right?
Changing parts is easy, Troubleshooting is an art
What kind of pulsing did you see on the fan control wire? If the fan really is the problem, then I'm wondering how the failure is getting communicated from the fan module to the IHKA module. One wire would mean a LIN network:
- JoesAutoElectric
- JoesAutoElectric
Sorry, no first hand experience on this one
You could try testing if the AC works when switched on above 30mph road speed as the condensor fan is switched off above this speed.
On fully automated climate control models the system can run a self-diagnostic by pressing the AC Auto and Air Distribution Mode while the key is turned from position 0 to postion 2. The test should be done it with bright light shinning on the sunlight sensor.
I haven't a clue about fault code 20 means but
Code 00 is no fault found.
Fault codes 11 to 14 are assorted temperature sensor faulta.
Fault code 21 & 22 are solar sensor faults
Fault code 31 &32 are air mix motor faults
Fault code 33 is distribution motor fault.
- Inge Jeppesen
- Ford master tech.
- Thank you received: 3
A 3 wire fan control module. The control wire to pcm is pw modulated.
What happens to the fords is that the controll wire corrodes till it breakes. Then the output monitor see no voltage on the wire and the ac clutch will not be commanded on.
If this is not your case, than I don't see how the pcm sees that the fan is not running.
- JoesAutoElectric
As for the wire corroding, I will say no because there is a signal being produced there from the PCM. So everything is good from the pcm to the fan. Perhaps it sees current draw when the fan is running? The downside of working on EU vehicles is the lack of information....
Did some more research, more confirmations on a fan failure preventing compressor engagement. Just thinking out loud, maybe get a used fan assembly and just plug it in? See if the compressor engages.
- ScannerDanner
- Administrator
- Thank you received: 500
Tyler wrote: I've heard of BMW's using this kind of protection strategy with their AC systems, so I wouldn't be surprised if the fan was the root problem. Not sure about the construction of this fan assembly, but is there a way to substitute a load (like a headlight) for the fan motor? Just to see if it makes everyone happy.
Couldn't have said it better myself Tyler
Don't be a parts changer!
- JoesAutoElectric
It would be nice to have some of this information available to us in the field so we do not have to guess at the strategy they are using. The longer I do this, the more questions I seem to have.
Thats where the forum comes in
JoesAutoTech wrote: Yes, I have recommended that we replace this fan assembly and was told it is too expensive of a repair. So...I guess I will not be able to confirm if this is a fix. I do appreciate the knowledge guys. It would be nice to have some of this information available to us in the field so we do not have to guess at the strategy they are using. The longer I do this, the more questions I seem to have.
I'm surprised! Customers will drive with ball joints falling out, on three cylinders, overheating, but ALWAYS fix the AC.
No worries on the fix, sir. I definitely learned something from this one. We really do get screwed when it comes to the Euro makes
