2017 Ford F350. P0402 and P0107. Fixed.
  • 70monte
  • 70monte's Avatar Topic Author
3 years 5 months ago #61648 by 70monte
2017 Ford F350. P0402 and P0107 was created by 70monte
This is a friend of mine's truck. It has around 32,000 miles and has the 6.7L diesel. His grandson borrowed the truck to pull his toy hauler travel trailer and on the way home the CEL came on.
I scanned it with my scan tool and these two codes came up. P0402 is EGR excessive flow and P0107 is MAP pressure sensor circuit low voltage.
I did some research online and there was information that stated that the EGR valve uses information from the MAP sensor to operate correctly.
The voltage reading with my scanner showed 0 volts for the MAP sensor. I then used my voltmeter and lightly touched the three pins of the connector and read 0.014 volts on pins 1 & 2 and 5.0 volts on pin 3. According to the 2016 F350 wiring diagram I could find, pin 3 goes to the EGR valve and the other two pins go to the ECM. I'm not sure if the 2017 has the same wiring setup.
Does anyone have access to the MAP and EGR wiring for a 2017 F350? Thanks.
3 years 5 months ago #61649 by Paul P.
Replied by Paul P. on topic 2017 Ford F350. P0402 and P0107
Never stop Learning.
  • 70monte
3 years 5 months ago #61653 by 70monte
Replied by 70monte on topic 2017 Ford F350. P0402 and P0107
Thank you Paul for the wiring diagram info. It looks the same as the one I saw online for the 2016. So right now I have 5 volts on the wire between the EGR and the MAP sensor. I'm not sure if that is correct or not. The info I read said I should have 5 volts coming from the ECM on pin 2 which I don't.
3 years 5 months ago #61655 by matrintrash
Replied by matrintrash on topic 2017 Ford F350. P0402 and P0107
That 5v seems shared ref voltage between MAP and EGR, test MAP ground and signal wire. If ECU reports that MAP is stuck out of range or doesnt move when turbine pumps, that means MAP is dead probably. I would check MAP with scope.
  • 70monte
3 years 5 months ago #61657 by 70monte
Thanks for the information. Pins 1 & 2 are reading the same voltage at 0.014 volts. If pin 2 is a ground, then the reading I had on it would be good. I'm not sure what voltage I should have on the signal return unless it is 5 volts.
When I was looking at the MAP voltage on the live data, I also had two different PSI pids pulled up and one was fixed at 50 psi and the other one was fixed low at I think about 5 psi. Neither of them responded if you increased the rpms.
3 years 5 months ago #61666 by Tyler
Replied by Tyler on topic 2017 Ford F350. P0402 and P0107
Pin #1 and #2 are stuck at zero, #3 is at 5.0V, correct? Pin 2 is the signal wire, so zero is a red flag.
Disconnect the MAP and recheck pin #2 for voltage. If it's at 5-ish volts, the MAP sensor has failed. Sensor time!
If still zero, short pin #3 to pin #2 across a 5K ohm resistor and recheck your scan data. Or, clear the fault codes and reread. You should now have a MAP circuit high code.
  • 70monte
3 years 5 months ago #61691 by 70monte
I did some more testing today.
Pin 1: 0.016 volts unplugged and plugged at the MAP connector.
Pin 2: 0.016 volts unplugged and plugged.
Pin 3: 5 volts unplugged and plugged.
Tested at the PCM connector:
Same voltages that I saw at the MAP connector except I did see 0.030 volts at Pin 2 with the truck running. I also used a piercing probe on the Pin 2 wiring at the PCM connector just to verify I was getting the same voltage that I did with back probing the connector.
I don't have any resisters so I was not able to jump Pins 3 & 2.
I don't have a wiring diagram to check the power and grounds at the PCM. The truck only has 32,000 miles on it so I would hate to think the PCM has an issue already.
This truck did have some previous rodent damage that the dealer fixed previously but this is the first time this code has ever set and the truck has been parked at a different property since the previous damage occurred.
I'm going to look around to see if I can see any wiring damage. Thanks for the information.
3 years 5 months ago #61738 by Tyler
Gotcha. As an alternative, you can ohm pin #2 (sensor disconnected) to ground. If it's more than 5K ohms, I'd say you're safe to short #2 and #3 together.
  • 70monte
3 years 5 months ago - 3 years 5 months ago #61752 by 70monte
Tyler, I did the test you requested. K ohms were 102.4 I shorted pins 2 & 3 together and did get a high circuit code of P0108 so the PCM is able to recognize the introduced fault. This test was done with the MAP sensor plugged in.
Last edit: 3 years 5 months ago by 70monte.
  • 70monte
3 years 5 months ago #61759 by 70monte
Does anyone have the power and ground wiring diagram for the PCM for this truck? Thanks.
3 years 5 months ago #61766 by Tyler
Perfect! I'd say you're done. The MAP sensor has 5V, ground and signal circuit integrity. The PCM is monitoring the MAP signal circuit correctly. Eyeball the MAP sensor connector for any pin fitment issues, then it's time for a new MAP sensor.
  • 70monte
3 years 5 months ago #61768 by 70monte
Thanks Tyler. Pin fitmit seems fine. I will tell him to get a MAP sensor. Thanks everyone for the help.
  • 70monte
3 years 5 months ago #61769 by 70monte
Tyler, I wanted to clarify something. This is what you said previously in the post. "Disconnect the MAP and recheck pin #2 for voltage. If it's at 5-ish volts, the MAP sensor has failed. Sensor time!"
I have checked Pin #2 unplugged and plugged and have never seen 5 volts at that pin. It's always around 0. Pin #3 is the only pin I have ever seen 5 volts on.
Is pin #2 the ground signal from the PCM since it's getting 5 volts from Pin #3?
3 years 5 months ago #61777 by Tyler
Negative, pin #2 is the signal wire. I grabbed a snip of the OEM diagram for reference:
Pin 1 is ground, pin 2 is signal, pin 3 is the 5V reference.
When I suggested that if you found 5V on pin #2, it was with the hope that Ford designed this signal circuit with a 5V bias. Would have made testing a lot easier. :(
But they didn't, so I suggested shorting between pins to verify signal circuit integrity. You got P0108 with pin 2 and 3 shorted, which means the signal circuit works.
  • 70monte
3 years 4 months ago #61900 by 70monte
Thanks Tyler for the clarification, Sorry for the late reply. I have been out of town on vacation for the past week and just got back today.
  • 70monte
3 years 4 months ago #61938 by 70monte
Replied by 70monte on topic 2017 Ford F350. P0402 and P0107. Fixed.
Just wanted to come back on here to say that I believe the truck is now fixed. I put a new Motorcraft MAP sensor on the truck and cleared the codes. We took it for a test drive and the truck had way more power and the CEL did not come back on. Before the sensor replacement, the CEL came back on almost immediately. The MAP sensor voltages looked normal and the one was not stuck at 0 like it had been before.
I want to thank everyone who commented and especially to Tyler who gave me good direction on where to go.
3 years 4 months ago #61973 by Tyler
Replied by Tyler on topic 2017 Ford F350. P0402 and P0107. Fixed.
Happy to hear it's back to running well. :)
Time to create page: 0.373 seconds
