Cranksensor waveform
- lwilliam22
9 years 4 months ago - 9 years 4 months ago #10153
by lwilliam22
Cranksensor waveform was created by lwilliam22
98 chevy 5.7 (R) motor, long crank on first start up in morning,runs fine after. Cranksensor waveform showing 0-6 volts, compare to another vehicle and many others that all run at 0-10. Is this a concern? I swapped a used sensor. Same reading. I thought if cranksensor wasn't good these (after long cranking) would default to cam sensor? Is my voltage an issue? Thanks still new to scope usage.
Last edit: 9 years 4 months ago by lwilliam22.
- Ben
- Thank you received: 215
9 years 4 months ago #10155
by Ben
Replied by Ben on topic Re:Cranksensor waveform
How long of crank ? Have you checked fuel pressure after sitting before and during this long crank?
9 years 4 months ago #10165
Replied by Tyler on topic Cranksensor waveform
Any trouble codes? If the PCM was going to a default strategy, I would figure it'd set some kind of code in the process.
The signal amplitude definitely sounds low... What do all three wires read, connected and unplugged, KOEO? Wondering about a supply problem to the sensor.
- lwilliam22
9 years 4 months ago #10175
by lwilliam22
Replied by lwilliam22 on topic Re:Cranksensor waveform
Only codes were p0171,p0174 lean but his air tube between mass air and hat was loose no clamp.I had a fuel gauge on and pressure was great in fact née pump had been installed a month ago. I checked power and grounds with it plugged in and it was 12v,with a good ground. He said usually the first crank in morning would almost go until the battery went dead,but after it started it would be fine just long period of time was the issue. I had fuel gauge on never dropped below 40 overnight and was good the second key was hit.
