Both upstream signal wires are maxed out
- Nali
What year/make/model/engine is your GMT900, specifically? That's important because some years ran a 450mV signal bias, and some use a 1900mV bias. Your specific Y/M/M/E will decide which one your truck uses.
Have the upstream oxygen sensors been replaced recently? If so, what brand of sensor?
- Nali
It's a 2012 Chevy Silverado 2500hd with a 6.0L flex fuel.
Gotcha. I snipped this from the P0132 'Diagnostic Aids':
This ECM uses a bias voltage on the high and low signal circuits of the HO2S. The voltage measured between the high and low signal HO2S terminals is approximately 1,900 mV. The voltage measured between the low signal HO2S terminal and ground varies based on the temperature of the HO2S and will typically be between 0 and 1,000 mV, under normal operating conditions. The value of the high signal circuit when measured to ground will be approximately equal to the voltage measured between ground and the low signal circuit plus 1,900 mV.
If you're using Global OBD data to observe the oxygen sensor signal voltages, then seeing 1.275V makes sense, since 1.275V is the highest that PID is programmed to read. The actual signal voltage is probably closer to the 1,900mV described by service info.
- Nali
- Nali
Yes. I changed the O2 sensors about six months ago and everything was fine until now.
So maybe my pcm doesn't like the bosch sensors????
I have replaced both sensors and they are Bosch.
I can almost guarantee that your ECM doesn't like Bosch sensors. :lol: Been here a couple times. There's something about this bias circuit that just doesn't play well with Bosch sensors. Very similar to the way aftermarket sensors don't play nice with Chrsyler/Dodge/Jeep/Ram NGC controllers.
Regardless of where you end up with this diagnosis, I'd change those sensors out with NTK or OE. They're available from RockAuto if you'd rather not visit your local dealer.
Before I messaged you I got the truck to operating temperature and both sensors were oscillating with a dvm connected to the signal wires.
Do you recall what the fuel trims were when you observed the oxygen sensor signal switching?
So since the bias voltage is correct what should the voltage be on the signal wire with a dvm attached when I force the signal wire high?
If you're forcing the signal high with a resistive short to power (like your body), then the signal will likely remain at 1.275V on your scanner, as the PID won't read any higher.
That 'Diagnostic Aids' snip I posted before pretty well outlines what voltages to expect at the oxygen sensor connector with a DVOM.
- Nali
The OEM sensors did the trick. Thank you. She's running like a top again.
Thanks for the follow up, great to hear!
