A/C Blowing warm air 2008 honda civic 1.8
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
3 years 4 months ago - 3 years 4 months ago #62060 by Mechanic 350
A/C Blowing warm air 2008 honda civic 1.8 was created by Mechanic 350
This is my personal vehicle. sprayed soapy water on all connection, no leaks. These are the readings that I took with the engine running and with the engine off. sorry but not too familiar in a/c readings. But I believe that my low side reading is good? (maybe). My compressor is turning with the clutch but I don't hear the clutch cycling on and off. Need some direction. Based on some research, it was suggested that I may need an expansion valve which I have never replaced in the system. everything else I have.
Last edit: 3 years 4 months ago by Mechanic 350.
3 years 4 months ago #62112 by Tyler
Replied by Tyler on topic A/C Blowing warm air 2008 honda civic 1.8
Sure looks like the pressures are not equalizing across the high and low sides. :unsure: I think you're right on with your suspicions of an expansion valve.
Fortunately, they're not too hard to replace on this year of Civic. Dash pull is not required, just the glove box and one half of the HVAC case.
