2005 1mzfe V6 fuel trim issue
- Morphman
See screenshot below.
Would it be possible for you to post the video that your fuel trim screenshots were taken from? Might help to see the fuel trim reactions in real time.
With the swings in the fuel trims bank-to-bank, my first thought is that the upstream AFR's are reversed. As in, the bank one sensor is connected to the bank two harness. In that condition, the trims will never be able to get things under control.
I know that on stock 1MZ applications, reversing the AFR connectors is pretty much impossible. But I figure at least a few modifications were needed to the 1MZ harness to make this engine swap work.
- Morphman
- Morphman
Can I post mp4 files here?
Unfortunately, the forums aren't set up to allow for MP4's.
If you like, email me at wrenchturnsyou@gmail.com and I'll upload it.
There are only the two upstream afrs in these builds.
Right. I'm wondering if the two upstreams are reversed.
- Morphman
- Morphman
- Morphman
- Morphman
I am completely perplexed, I thought it maybe a vac leak between the maf and the intake but I can't find anything. Several cans of brake cleaner and nothing.
- Morphman
- Morphman
- Morphman
- Morphman
This really is giving me a pain now
- STIMECE
- Thank you received: 2
Your first order of business is to create rich and lean conditions for the car and see if you can get your upstream to react....report back whenever you get that done.
For a rich condition, I use propane in the intake tube
Edit: Why is your bank 1 sensor sensor 2 showing 0v? that should be your downstream in your cat. That engine doesnt have two cats....so you dont have a voltage reading for bank 2 sensor 2 which makes sense
- Morphman
There are only 2 afr sensors on this, no o2 sensors.
- STIMECE
Low voltage on the downstream is lean. I know the upstreams will adjust the LTFT and STFT readings but I am not 100% sure how the downstream will factor in that.
- Morphman
- Morphman
- Morphman
