golf erratic idle
- shayan27
9 years 4 months ago - 9 years 4 months ago #10392
by shayan27
golf erratic idle was created by shayan27
hi i am working on golf 2000 1.6 AKL .I replace spark plug and coil pack now it idling erratically between 900 and 1400 strange thing to me is when i pull the hose from canister to manifold it start stumble as soon as i re connect it idling fine till i rev it again. i should mention i did not remove TB scan tool just giving me very limited data which are
air mass per stroke 103 mg/h converted to second is 0.02861 not sure if this is acceptable for this car
injector time 3.40m/s
throttle angle 3.00 degrees
ground current 2.8 g/s have no idea what that mean
hill climbing -13 to -15 no idea
engine speed 830
temperature 95
data when running erratically
air mass per stroke 92 to 119
throttle angle 4.5 degrees to 6.5
injector time 2.9 to 3.4 m/s
ground current 2.8 to 4.3 g/s
hill climbing -14 to -19
engine speed 980 t0 1400
temperature 95
i really would appreciate your input.
with Regards
Farshad.
engine speed 830
temperature 95
temperature 95
with Regards
Farshad.
Last edit: 9 years 4 months ago by shayan27.
- Ben
- Thank you received: 215
9 years 4 months ago #10398
by Ben
Replied by Ben on topic Re:golf erratic idle
Does it have an electric throttle body ?
- shayan27
9 years 4 months ago - 9 years 4 months ago #10405
by shayan27
Replied by shayan27 on topic golf erratic idle
Hi ben it has cable on one side and black attachment on other side like flyby with six or seven wire going in to it.
Thanks
Thanks
- Ben
9 years 4 months ago #10407
by Ben
Ok this is an drive by cable with an idle motor and encoder and it sounds like it may need an adaptation done as long as you have no vacuum leaks you can try the chicken dance (as it is called on the internet) I gave steps towards the end of this post on how to do it
www.scannerdanner.com/forum/post-your-re...el-but-no-start.html
I've personally never tried it. I use a ross tech vag com and I have performed plenty of adaptations for people who have tried this method and it did not work for them so no gurantees
- shayan27
9 years 4 months ago #10419
by shayan27
Replied by shayan27 on topic Re:golf erratic idle
Hi ben thank you i give it a go.
- AlphaMM
9 years 4 months ago #10420
by AlphaMM
Replied by AlphaMM on topic Re:golf erratic idle
What's the short and long fuel trim numbers at idle? And what at 3000rpm ? It could be a vacuum leak. This ones you just touch them end thay fall apart. .
Sent from my SM-G900I using Tapatalk
- Ben
9 years 4 months ago #10496
by Ben
Any luck on this 1?
