12 volts not present at the ignition coil
  • angelcoamo44
  • angelcoamo44's Avatar Topic Author
3 years 3 months ago #62442 by angelcoamo44
12 volts not present at the ignition coil was created by angelcoamo44
Hi...The vehicle is a 1996 Mitsubishi montero 3.0L 12V....It doesn't start, no spark, check engine light doesn't shine in the dashboard (bulb is good)...I need to know if it is a grounding issue of the ecm...How can I obtain a picture or diagram showing the physical location of these grounding points..?...Can I take the grounding pins on the ecm and ground them on other location...?...12 volts are not present at the ignition coil...How I can get 12 volts at the ignition coil in order to get a spark.?..Help please...
