Gas light and gage no working
  • calobeto.ibarra
  • calobeto.ibarra's Avatar Topic Author
3 years 3 months ago #62494 by calobeto.ibarra
Gas light and gage no working was created by calobeto.ibarra
07 dodge caliber fuel light and gage no working I already changed the fuel level sensor even know it reads 1.12v so it is making voltage
  • calobeto.ibarra
3 years 3 months ago #62497 by calobeto.ibarra
Replied by calobeto.ibarra on topic Gas light and gage no working
And both signals come in from the cluster to the fuel pump module
Grounds are good and when I do a bidirectional control I'm able to make the light go off but I can not get the gage respon from the light going off
3 years 3 months ago #62509 by ferris48
Replied by ferris48 on topic Gas light and gage no working
From identifix:
Try running the self test on the cluster by starting with the key in the off position. Hold the trip reset button down while turning the key to the "on" position. The cluster will enter the self test mode. All dash gauges and warning lights will comes on. Pay attention to the illumination during the test. If it does not come on, then the cluster has failed.
Demonstrated in video below @54 seconds in
  • calobeto.ibarra
3 years 3 months ago #62512 by calobeto.ibarra
yes, I did this test and it passed , all the gages work(move normal) and like I said I can do a bidirectional control with the scanner I think the cluster is good because only the the gas circuit is the problem light and gage
grounds are good and like Paul says the flout is making voltage (1.12v)plug in
the fuel pump has 10.46v plug in
thanks for time man
  • calobeto.ibarra
3 years 3 months ago #62518 by calobeto.ibarra
But no luck still
Time to create page: 0.382 seconds
