09 town and country with a 3.8 code p0135
- groundblind
James C Paxton
Service information states that heater voltage is pulse width modulated via the ECM (brown & tan) with a chassis ground (black).
So you will likely only have pulsed voltage on the heater control wire (not full battery voltage as measured with a meter) when the engine is running.
It's relatively easy to disconnect the oxygen sensor connector, identify the heater circuit pins, and connect a lightbulb between the two wires as a substitute load.
You may need to clear the codes, then start the engine. Within a few moments, the bulb should begin to flash and grow brighter as heater command is increased. If that's the case, then the sensor is the issue.
To answer your question, the O2 heaters in your Town and Country will only have 12V on the heater control circuit when the PCM is commanding the heaters on. This system uses a high side driver to switch 12V on the control wires, while the other side of the heater is grounded all the time. The PCM will pulse width modulate the 12V power as needed to get the sensors warmed up.
Interestingly, your P0135 does not spell out a heater circuit problem. :huh: I snipped this from service information:
Theory of OperationThe Powertrain Control Module (PCM) performs a continuous check of the O2 sensor heater circuit during operation. The heater circuit is momentarily disabled to allow a resistance measurement to be taken to infer heater temperature. The current delivery to the heater is duty cycled to maintain a specific target temperature. The error from the target temperature is continuously monitored to assess heater performance.
- When Monitored:With the engine running, O2 sensor heater duty cycle greater than 0%, and battery voltage greater than 11.0 volts.
- Set Condition:The PCM detects no O2 sensor output when the heater is powered up. Two trip fault. Three good trips to turn off the MIL.
In other words, the PCM is inferring heater operation by the behavior of the O2 sensor signal. Keep in mind that there are also several other faults that relate directly to the upstream O2 heater circuit (P0030, P0031, P0032, P0053).
If I were you, I'd suggest monitoring the upstream O2 sensor signal with a scan tool during a cold start. If the sensor is heating up like it should, the signal should drop well below 3.5V and start toggling once closed loop is achieved. If you have a scan tool with the O2 Heater Test, you can use that to command the heater circuits on and observe the sensor signal without the engine running. Again, the signal should drop well below 3.5V within a minute or two.
Has the upstream oxygen sensor been replaced before?
- ScannerDanner
- Administrator
- Thank you received: 500
Man, the forum looks like s--t. Working on it, unfortunately it is the last item on the list, but we will get to it. Thanks so much for your patience and for always holding this part of my fort down for me.
Don't be a parts changer!
- ScannerDanner
- Administrator
And man is this always this slow when I hit submit?
I just posted the same thing 4 times, hit submit twice and the browser just spun. smh. I assume this is new since the joomla 4 changeover? (the mess everything has been in the past 2 days)
- juergen.scholl
- Active partschanger
- Thank you received: 462
The number of posts per page is drastically reduced as well.
- ScannerDanner
- Administrator
- juergen.scholl
Thank you's go out to your team and yourself for all the good things you're doing.
Hey, they're your forums!Can I swear lol?
Yeah that's new, but I figured there'd be some things to work through with the changeover.I just posted the same thing 4 times, hit submit twice and the browser just spun. smh. I assume this is new since the joomla 4 changeover? (the mess everything has been in the past 2 days)
