Hard starting, no turn signal, no wiper, but hazard
  • davidessiendcarguy
  • davidessiendcarguy's Avatar Topic Author
3 years 2 months ago #62694 by davidessiendcarguy
Hard starting, no turn signal, no wiper, but hazard was created by davidessiendcarguy
2005 CHRYSLER 300 3.5L V6 2WD AUTOMATIC 150,127 MILESThe car listed above is limited and according to the client had a horn issue so was taken to a garage. Although the horn later worked, a more complex issue happened to the car. A no crank no start and also a crank no start, whenever security light came up it doesn't start or start and stalls immediately. Infact, ECM was replaced by the engineers but that didn't fix the issues. I finally fixed all these issues listed above with both new and an old ECM. When I was about to go, the client pleaded for me to help him fix these issues below, such as, hard starting, single turn signal for both sides doesn't work but hazard light blinks normally when the switch is turned on, wipers doesn't work too. Mostly for the trafficator / turn signal that wasn't functioning, what could make it to be inoperative and, how can I fix the problem in that car? Can you guide me please, on the repair procedure and wiring diagram to help me fix the problem?This was the codes I got below
drive.google.com/file/d/1nZQtpE8DuGGQoeA...0H/view?usp=drivesdk
  • Does it require a TIPM or trafficator switch replacement? Please, how can I carry out a test to verify if it's TIPM or a trafficator switch that is faulty?
