2012 F-250 6.7 P20C2
- PDM
- Thank you received: 56
3 years 1 month ago #62948
by PDM
2012 F-250 6.7 P20C2 was created by PDM
Can someone with access to Ford service info do me a solid and look up DEF heater "C"?
A shop replaced the tank heater/sending unit which was not a fix. The heater that was removed checks good at 2.0 ohms with a multimeter. I'm wondering if heater "C" is for the pump heater. Searching the interweb hasn't produced any answers.
- Hardtopdr2
- Thank you received: 150
3 years 1 month ago - 3 years 1 month ago #63018
by Hardtopdr2
Replied by Hardtopdr2 on topic 2012 F-250 6.7 P20C2
that is a "reductant heater C control circuit performance code" they/you need to test the relay for that circuit, pcm to relay wires and wiring to/from relay to the reductant heater including powers and grounds of heater at heater and ground point.
Last edit: 3 years 1 month ago by Hardtopdr2.
- PDM
3 years 1 month ago #63074
by PDM
Replied by PDM on topic 2012 F-250 6.7 P20C2
Heater "C" is in fact the tank heater. Turns out the driver was cooked in the glowplug module. No idea why.
- Bryan Pollock
- Thank you received: 3
3 years 1 month ago #63104
by Bryan Pollock
Replied by Bryan Pollock on topic 2012 F-250 6.7 P20C2
First thing , sorry I'm just seeing this 2 weeks after you posted it. I try to check out the diesel questions more regularly. There is a 25 amp fuse in the battery junction box. It should be fuse # 27. You need to check for B+ KOEO while commanding the heater with a scan tool at pin 16 (should be white and orange wire) at the glow plug control module. That input is controlled by the reductant heater relay which is powered by fuse 27 in the battery junction box. If the fuse is good but you still cannot command power you will have to do some regular relay checks at the reductant heater relay
- ScannerDanner
- Administrator
- Thank you received: 500
3 years 1 month ago #63107
by ScannerDanner
Don't be a parts changer!
Replied by ScannerDanner on topic 2012 F-250 6.7 P20C2
Test for reply notifications
- Bryan Pollock
3 years 1 month ago #63109
by Bryan Pollock
Re double reply test
