no crak or start
  • ford f150
  • ford f150's Avatar Topic Author
3 years 1 month ago - 3 years 1 month ago #63009 by ford f150
no crak or start was created by ford f150
1992 ford f150 5.0 5sp new battery and cables new alt starter disturbtior module key switch ing switch on stering coulm and the fuel line gets hot by the fuel pressure regulator
Last edit: 3 years 1 month ago by ford f150. Reason: more info
3 years 1 month ago - 3 years 1 month ago #63010 by Tyler
Replied by Tyler on topic no crak or start
Start simple. With the key in crank, measure voltage at all four posts of the starter solenoid (in the engine bay, not at the starter motor itself). Three should read 12V, one should read zero. Or, if your solenoid only has three posts, all three should read 12V.
What are your readings?
Last edit: 3 years 1 month ago by Tyler.
  • ford f150
3 years 1 month ago #63051 by ford f150
Replied by ford f150 on topic no crak or start
hi one post is 12 volts and one is 0
