Fuel Trims constantly in the negative - 2008 Honda Civic LX 1.8L Non-Vtec
  • Mechanic 350
  • Mechanic 350's Avatar Topic Author
3 years 1 month ago #63082 by Mechanic 350
So this is my personal vehicle.  Placed the scantool on it, and I'm constantly getting fuel numbers in the negative all the time.  so I need some direction as to which way to go.  My miles per gallon could improve a little bit.  so the question is, how do I get my numbers as close to zero as possible?  Because as I was studying, the #1 job of the LTFT is to keep the STFT close to zero.  and that's not happening.  please advise.
3 years 1 month ago #63083 by juergen.scholl
Your description suggests you 're basically dealin g with negative SHORT TERM fuel trim numbers. Nevertheless it will be helpful to clarify what long term and total fuel trim is doing. Also the trim trend with varying rpm and load conditions.
Things to look at would be fuel pressure, improper air metering, evap purge solenoid.....to beginn with.
  • Mechanic 350
3 years 4 weeks ago - 3 years 4 weeks ago #63143 by Mechanic 350
Hey Juergen, my exact condition is this.  I have a Lean Command in response to a rich condition. So can I remove the 02 sensor, clean it with a wire wheel and cleaning it with spray, put it back and then take it for a drive and see to see what the fuel trims report.  What say you?
Last edit: 3 years 4 weeks ago by Mechanic 350.
3 years 3 weeks ago #63160 by Noah
Mechanic 350 wrote: So this is my personal vehicle.  Placed the scantool on it, and I'm constantly getting fuel numbers in the negative all the time.  so I need some direction as to which way to go.  My miles per gallon could improve a little bit.  so the question is, how do I get my numbers as close to zero as possible?  Because as I was studying, the #1 job of the LTFT is to keep the STFT close to zero.  and that's not happening.  please advise.
As Jurgen suggested, what exactly are the LTFT & STFT  values across the operating range of the engine?
If we're talking +/- 10% total correction, there's probably not a whole lot to do.
  • Mechanic 350
3 years 3 weeks ago #63161 by Mechanic 350
yes, long and short term are definitely under 10%. so i just will probably clean the 02 with a wire wheel just to be anal about it. thanks Noah.
  • Mechanic 350
2 years 11 months ago #63502 by Mechanic 350
My fuel trims, short and long, are all negative reading during idle and during 2000 rpm range. The lean command, (PCM) is constantly taking fuel away. I'm going to hook up my verus and T pin the black wire as my signal wire and see what the scope shows me. besides that Noah, I don't have any direction. Remember, I'm not a mechanic. Just an experienced DIYER. What say you buddy?
2 years 11 months ago #63504 by Noah
You still haven't given us any actual fuel trim values other than "negative", so it's hard to say.
If I was going to pull a random ticket out of my bag of Honda tricks, I'd say a valve adjustment probably wouldn't be a complete waste of time.
They need to be adjusted periodically anyway, and if you've never done it, it's probably never been done.
Misadjusted valves can result in low vacuum, which will be interpreted as load by the computer resulting in more fuel than needed, and in some cases, negative fuel trim. You could see this reflected in higher than normal MAP voltage at warm low idle. If memory serves, I think 1v or less is the spec....
  • Mechanic 350
2 years 11 months ago #63505 by Mechanic 350
I haven’t adjusted the valves yet. But because you suggested it, I’ll do that first. The thing is I can’t report to you any positive numbers because they’re aren’t any. The idle is in the 600 to 700 rpm range.
Do you know how to do a screen grab on a verus? I’m still trying to learn this tool. Then I can send you the screen capture. So you see what I see.
2 years 11 months ago #63511 by Noah
Press the S button, it should bring up a drop down menu on the screen where you can choose to take a screenshot.
Also, you can save a test drive and share the
.vsm file, then anyone with Shop Stream Connect can open and view the file as if it were on their own scan tool
The following user(s) said Thank You: Mechanic 350
  • Mechanic 350
2 years 11 months ago #63512 by Mechanic 350
ok I'll do that.
  • Mechanic 350
2 years 11 months ago #63517 by Mechanic 350
I figured out how to take the captured photos. Now, where can i find the screened shot photos along with the .vsm file. I think i saw 7,000 plus frames while I was test driving the vehicle. I don't have shop stream connect. by the way, I couldn't find 02 SENSOR voltage pid. it's crazy. I know I must be overlooking something.
  • Mechanic 350
2 years 11 months ago - 2 years 11 months ago #63519 by Mechanic 350
Last edit: 2 years 11 months ago by Chad.
  • Mechanic 350
2 years 11 months ago #63520 by Mechanic 350
sorry for this whatever it is in the post. if you can delete it, please. but these are the photos.
  • Mechanic 350
2 years 11 months ago #63525 by Mechanic 350
I made 2 files and they're in data manager in shop stream. don't know how to retrieve it. there you could see different rpm ranges that I performed during the drives. thanks for your help Noah.
2 years 11 months ago #63527 by Chad
There was a problem with inserting files. The problem has been fixed, now.
The following user(s) said Thank You: Noah, Mechanic 350
2 years 11 months ago #63529 by Noah
Unfortunately I can't make out a single picture. I don't think it's anything you did, just how the forum uploads them. When you do it again, include engine rpm, loop status (so we know if the trims are actually doing anything), MAP voltage and temperature so we can tell how the fuel trims react to changes in engine speed and load.
Also, you will not find a PID for bank one sensor one oxygen sensor as it does not have one.
The wideband air fuel ratio sensor pid will be displayed in milliamps. The pid will be something like AFSENS 1
  • Mechanic 350
2 years 11 months ago #63530 by Mechanic 350
I took a video and saved to my verus. I don't know if it's available in shop stream for you to view. next video I'll include what you have told me:
1. engine rpm
2. Loop Status
3. Map voltage
4. Temperature Pid
any suggestion as to how I can upload the video from my Verus I took yesterday to the forum?
What I definitely noticed yesterday during the test drive, was that STFT did not drop below 800ihs to 1 volt. It never switched.
2 years 11 months ago #63532 by Chad
www.scannerdanner.com/forum/off-topic-se...-a-member.html#63531
  • Mechanic 350
2 years 11 months ago #63534 by Mechanic 350
hey I have 3 files in shop stream for you to look at. the're in the documents library under the following headings:
11-16-23 civic
11-16-23 civic 2
11-17-23 civic 3
  • Mechanic 350
2 years 11 months ago #63535 by Mechanic 350
if you have your Chats again with other mechanics, I would like to attend. please let me know. thanks
