Possible MAP sensor problem?
- LavishAutomotive
- Thank you received: 2
I have a Snap-on Apollo-D9 if youd like snap shots or recordings.
Help me so Im not a parts changer. I appreciate your help!
- juergen.scholl
- Active partschanger
- Thank you received: 462
Did I understand this correctly? If so, was this read on the generic OBD2 side or Mazda manufacturer protocol?
- LavishAutomotive
Youre right. The readings were read on my Snap on scan tool. Was not a Mazda diagnostic tool.
Thats just what i had seen while seeing why the car is somewhat struggling to accelerate.
- juergen.scholl
What are the map values in generic OBD2, koeo and koer?
- LavishAutomotive
I appreciate you helping me. all i can see is inHg for my MAP which is 28.9 Koeo and 8.0 koer. Do i add 20 to my Koer value? Or is that a Vac leak?
- juergen.scholl
I don't see a problem there , the numbers suggest the engine
does not have a leak issue and the sensor works fine.
- LavishAutomotive
- LavishAutomotive
I must have a fuel component giving me alil to much fuel?
- juergen.scholl
- LavishAutomotive
At 1500 they are -0.7 STFT And -7.0 ltft
2500 they are 0.0 stft and -7.0 ltft.
Thank you!
- juergen.scholl
Does the fuel pressure hold for a while after engine shut down?
- LavishAutomotive
The issue seems to only show itself while acceleration even during light throttle until 3k rpm then seems ok, and while at steady speed it has small hiccups. Should i monitor my throttle postion sensor and look at my VTCS solenoid?
Also, my spark plugs are less than a year old, however, are Autolites. I might try OEM NGKs that are OEM heat range.
I have ran into a vehicle where it had a misfire and owner used to cheap of plugs that made the misfire worse and had to use OEM plugs.
- juergen.scholl
- LavishAutomotive
I greatly appreciate your feedback as well!
It might sound stupid, but it's hard to experience what you are feeling from this side of the internet
- LavishAutomotive
However, i got a P2188 which is rich at idle. Before i also had a P0128.
My thermostat definetly needs changed, could also be my temp sensor. My fuel trims are always negative and my ECT doesnt get above 170⁰. Driving i saw it get down to 164⁰.
Im going to replace T-Stat and probably my ECT sensor, then monitor everything again.
- LavishAutomotive
Just giving everyone an update. I replaced my thermostat and my readings are alot better. ECT is where its suppose to be and my Fuel trims together are where they should be as well.
I appreciate all the help and input!
- LavishAutomotive
I seem to still have an acceleration issue and one at cruising speeds. During acceleration it is jerky but not like a misfire and also feels like im trying to accelerate in a higher gear at lower RPMs. I get a feeling of it being held back or choked. And at cruising speeds you can feel a light stutter.
This happens only up until 3k, then seems to clear itself or catch up with itself. What do you suggest i look into?
Ive actually been dealing with this for alittle over a year, and the only CEL ive gotten was related to my thermostat being stuck open and rich at idle.
I appreciate all your help!
