Rich system code p0172
  • arist1976
  • arist1976's Avatar Topic Author
2 years 11 months ago #63495 by arist1976
Rich system code p0172 was created by arist1976
I have a Chevrolet Lacetti 1.6 gasoline 2007  model and I got error code p0172. This model has not MAF sensor and the MAP seems to be ok. Also with the OBD2 scanner I have LTFT -9% and STFT -27%. The calculated engine load at idle is 43% and both O2 sensors are 0.9V. I changed the upper O2 sensor but still is high(0.92V). Also the car is stalling. I cleaned the EGR valve and the pcv valve is ok. Any help,please?
2 years 11 months ago - 2 years 11 months ago #63575 by Paul P.
Replied by Paul P. on topic Rich system code p0172
I would expect to see 18-25%ish for the MAP at idle. @ 43 % the PCM thinks the engine is under load and will fuel for it, but your engine is a idle, so there is a major fuel correction.  Do the Fuel Trims improve; ie. go positive with increased load and RPM?
At Key On, what is your BARO PID read?...............................Should should be within +/-1 of what your local weather station states.
At idle what does the MAP PID Read?
BARO - MAP will give you the intake manifold vacuum. You should be 16-21 in HG.
Couple of option, a skewed Map Sensor, or an air leak in the intake.
Never stop Learning.
Last edit: 2 years 11 months ago by Paul P..
The following user(s) said Thank You: arist1976
  • arist1976
2 years 11 months ago #63585 by arist1976
Replied by arist1976 on topic Rich system code p0172
Tha MAP shows 30HG with the engine off and 15 at idle.
2 years 11 months ago #63586 by Paul P.
Do the trims Improve with increased Engine Load and RPM?  If they do start checking for a vacuum leak.
  • arist1976
2 years 11 months ago #63588 by arist1976
Thank you. I will check it and inform you.
2 years 11 months ago #63625 by 70monte
Replied by 70monte on topic Rich system code p0172
Doesn't a vacuum leak set lean codes and not rich ones?
2 years 11 months ago - 2 years 11 months ago #63626 by Paul P.
70monte, thanks for waking me up !
This is a MAP Speed Density Engine.  Any increase in manifold pressure increases the MAP voltage, the PCM interprets this as increased loaded and it will add fuel for it.  If the O2's are working correctly they will remain rich and the PCM will start removing fuel.
A vacuum leak would have a raised idle RPM on this engine.
Having Negative Trims and Higher Calc Load at idle on this engine is indicitive of an exhaust restriction, or engine valve timing or tight valves.
It would be nice to know what the how the trims behave with higher engine load and RPM.  Do they improve? Or stay Negative?  That would give us much clearer diagnostic direction.
Last edit: 2 years 11 months ago by Paul P.. Reason: Content
The following user(s) said Thank You: Noah, 70monte
  • arist1976
2 years 11 months ago #63645 by arist1976
No they dont change.
  • arist1976
2 years 11 months ago #63646 by arist1976
They stay negative and does not improve.
2 years 11 months ago #63648 by Paul P.
1.The stalling, does it stall at idle?
2.Or does it stall put in gear and trying to increase engine rpm?
3.Does the Engine Lack Power?
4.Is there fuel in the engine oil?
5.When snapping the throttle what is the highest you can get the Map Pid? and the CALC LD, want to see min 70-75% CalC Load.
6.If Sensor 1 O2 is reading rich, is the Sensor 2 reading rich as well?  (If the second is lean, one of them is not reporting correctly)
7. Engine Coolant level has not gone down?
8. Verify with a scan tool the IAT and ECT are within a few degrees when cold, and that the ECT does get to 180-190 operating temp.
Need a little more data please.  The fact that the trims don't change at higher Engine Load rules a few things out.
So far, Fuel Pressure(high), Leaking Injectors, Exhaust restriction, and engine Valve/timing are suspects
  • arist1976
2 years 11 months ago #63676 by arist1976
1) yes
2) yes, mostly when it is cold.
3) yes
4) I think so.
5) I think 80%. I'll try and come back.
6)They are both high. First is about 0.95 and second at 0.94.
7) I had a little leak from hose that goes to the water canister, so I do not know for sure but I do not think so.
8)Ok. I'll check and come back.
Thank you. It is a puzzle.
2 years 11 months ago #63695 by Paul P.
At this point to rule out a few things, pull the first O2 and run the engine, it'll be in open loop, but is there any improvement in power and trims?  This will rule out a plugged catalytic convertor.
Get a fuel pressure guage and verify the fuel pressure.  I do not know the Spec on this system.
Also, the vehicle is Multi Port Injection?  Is there a pressure regulator on the fuel rail with a vacuum line?  or is there a fuel pressure sensor? It will be the 3 wire variety?
  • arist1976
2 years 11 months ago #63742 by arist1976
The first O2 sensor is replaced with a new one. Yes, it has a fuel pressure regulator.
2 years 11 months ago #63776 by Paul P.
If there is a vacuum line on the regulator pull it off, there should be no fuel here, if there is, replace the regulator.
Will the this engine run with the MAP unplugged? If so, what do the trims do?
  • arist1976
2 years 11 months ago #63783 by arist1976
I'll check and update.
  • arist1976
2 years 10 months ago #63941 by arist1976
When I unplug the map sensor the car is not working properly.
  • arist1976
2 years 5 months ago #65764 by arist1976
Finally I found the problem. The map sensor's vacuum hose had a leak. Now the is working fine and the fuel consumption is down at about 20%. Thanks for all your answers.
The following user(s) said Thank You: Noah, faisalkk
