Looping lines on rack and pinion
- Donnyten
- Thank you received: 2
I don't intend on fixing it anytime soon because I don't have the money so instead of investing in a new rack and pinion I was going to remove the power steering pump and get as much fluid out of the rack and loop the lines.
In the long run will this damage anything? Rack or steering column?
- Ben
- Thank you received: 215
Is this the 2.2L engine? You can totally take the pump off if you want, but I figure removing the belt would be good enough? I don't recall those cars running that much caster, so steering effort probably isn't that bad... :huh:
Ben wrote: Well this is more a matter of opinion than a factual kind of thing personally if this were me I would start with blue devil stop leak (that stuff never ceases to amaze me!)
Wow, I didn't know Blue Devil made a PS stop leak. O_O Their head gasket sealer stuff really is amazing. Fixed a cracked Northstar block with it a few years ago.
- Donnyten
Its the 2.2l
If that doesn't work ill just loop the lines and call it a day.
Would keeping a little bit of fluid in it prevent it from totally failing? Or is pump pressurization needed?
Guess im just drawn to eliminating a potentially failing and antiquated piece of technology... fluid is messy and some newer cars seem to have electric power steering
Donnyten wrote: Hmm. Im getting mixed opinions that a stop leak product may not work on a 20+ yr old car. No one says why...Guess I could just try it.
Always a gamble, depending on the nature of the leak. The end seals on your rack may be too far gone at this point? Not much to lose at this point, IMO.
Can't hurt! Maybe brim the lines right before looping.
Yeah, Toyota got a lot of things right, but not hydraulic power steering. :lol: Even newer models have blown rack boots and leaking hoses.
Auto transmission Stop Leak worked a treat on my 25 year old trolley jack that was leaking from the pump.
If you're fine with not having power steering, pull the belt and call it a day.
Adding fluid to the rack is a moot point considering it's just going to leak out the seals anyway.
I would try that blue devil or some other stop leak product.
I had a Cherokee like the one that burnt up on Paul and the Pittman arm seal was so far gone that you couldn't add fluid with out it pouring out before you got in the truck!
Lucas stop leak would stay in the box for a couple weeks, but on cold winter mornings, filled with nothing but Lucas, she was a bear to drive to work!
