2016 mazda3 with po192 , 193, and po606 .
  • Lupe
  • Lupe's Avatar Topic Author
2 years 10 months ago #63880 by Lupe
was about to replace high volume fuel pump , it will only gets  up to 45 mph.  but when i check voltage at pump solenoid connector only got 2.9 volts insted of 12 , so something is grounding it           right ? any ideas will be helpfull  . checked fuses, and looked at wiring  does that wire go to fuse box so i can jump it , to check if pump will run ' thks before ..g b
2 years 10 months ago - 2 years 10 months ago #63884 by Paul P.
Replied by Paul P. on topic 2016 mazda3 with po192 , 193, and po606 .
The P0192,93 are causing the PCM to disable control to the HP Pump.
The P0606 might be the cause or effect of the PCM's disabling strategy.  It is a CPU internal processor malfunction.  But cover your bases and make sure the Fuel Pressure sensor circuitry is good and no shorts to ground are present.
The  3~ish volts you are seeing is more than likely a Bias voltage and it should be present on both wires the Tan and Yellow.  This will show the solenoid is not Open.
Address the Fuel Pressure sensor first, it is a three wire design:
A. Tan = Sensor Ground
B. Green = Sensor Signal
C. Purple = 5 volt Supply
I'm unsure of the sensor design, whether it is pull-up or pull down.
With the Key ON, sensor unplugged;
1. What is the voltage level on the Green wire?
2. What is the voltage on the Purple wire?
3. Will a small test lamp (less than 1 amp) light when connected to battery positive and the Tan wire?
If 1. is 0 or 5V; 2 is 5v and 3. does light;
With the key on, sensor unplugged;
1.  Jump the Purple to the green wire, the scan tool should report maximum pressure.
2.  Jump the Green to the Tan wire, the scan tool should report minimum pressure.
Verify that the Low Pressure pump is operating correctly.
If the scan tool reports Max and Min values, replace the sensor.
Never stop Learning.
Last edit: 2 years 10 months ago by Paul P.. Reason: Content added
The following user(s) said Thank You: Chad, Lupe
  • Lupe
2 years 10 months ago #63887 by Lupe
paul the g wire 5 v p=5v b=does light bulb '
the 606 code was earsed but now have b108e:04-ob
i might wiring problems but going by your tests . going to put new pressure sensor. the jumper test 5v p to g and no v from g to ground wire Thanks amigo G B
  • Lupe
2 years 10 months ago #63959 by Lupe
UPDATE PAUL THANKS AGAIN
replaced pressure sensor and rail , that did it.
HAPPY HOLIDAYS TO YOU AND YOUR TEAM !
2 years 10 months ago #63962 by Paul P.
Thank-you, glad you made out ok.
I'm a member here just like yourself, Mr. Paul Danner is the proprietor of this site he has some very talented Mods helping all of us!
Merry Christmas.
