4 pin temp sensor
Nate290
Offline
New Member
Thank you received: 0
2 years 9 months ago #64223
by Nate290
Hi, new to all this and enjoying the scanner danner content. So please bare with my novice questions.
I have an 84 vw t3 that I want to test the 4 pin temp sensor connector.
Unplugging with ignition on, what should I be seeing testing each individual pin.
I've done an Internet search re the 4 pin connector but have found nothing on them to give me any ideas.
Kind regards
Thank you received: 254
2 years 9 months ago #64232
by Tutti57
Are you sure it's a temperature sensor? They are usually only 2 wires.
Is it a connector that is shared by a temp sensor and something else?
What type of temp sensor is it, coolant?
Nate290
Offline
New Member
2 years 9 months ago #64241
by Nate290
Hi, thanks for your reply.
It's a green coolant sensor with four pins. Essentially just operating the dash guage as the vehicle doesn't have an ecu.
So it's not giving a signal to an ecu, and the fuel pump is ID, mechanical.
I'm familiar with a two pin, but four is something I've not been around.
Cheers
Time to create page: 0.245 seconds
