'95 S-10 cranks but won't start
9 years 3 months ago #10971 by Estep
'95 S-10 cranks but won't start was created by Estep
1995 S-10 4.3L Vortec "vin W"
Engine cranks but won't start without a shot of carb cleaner in the intake. Key-on-engine-off fuel pressure reads 50 psi and holds pressure after turning the key off. Engine-on fuel pressure is about 53 psi, jumps up to 60 when given throttle, and holds pressure after turning engine off. Any ideas why this thing won't start? Thanks in advance.
9 years 3 months ago #10972 by Ben
Replied by Ben on topic Re:'95 S-10 cranks but won't start
So after you start it on carb cleaner it stay running on it's own?
9 years 3 months ago #10973 by Estep
Replied by Estep on topic Re:'95 S-10 cranks but won't start
Yes it stays running.
9 years 3 months ago - 9 years 3 months ago #10992 by Noah
Replied by Noah on topic Re:'95 S-10 cranks but won't start
Hmmm...
Fuel pressure seems fine, although on the low side of spec.
I assume that also means you're getting the 2 second key on prime, so the pump relay should be OK. (If you're not getting the two second prime, that would explain a lot.)
It keeps running after a shot of carb cleaner, so it doesn't sound like an anti theft issue.
Is there injector pulse during cranking if you don't give it a shot?
I'm split between maybe a failing crank sensor that doesn't trigger the vcm until the engine gets up beyond cranking speed, or a voltage drop on the injector circuit (battery, terminals, crappy relay contact) that is overcome when the alternator is charging.
I'm interested to see where this one goes...
Last edit: 9 years 3 months ago by Noah.
Time to create page: 0.258 seconds
