Whats making my relative throttle % come down?
- LavishAutomotive
- Thank you received: 2
2 years 8 months ago - 2 years 8 months ago #64703
by LavishAutomotive
Help me so Im not a parts changer. I appreciate your help!
Whats making my relative throttle % come down? was created by LavishAutomotive
Hi Current vehicle is a 2007 Mazdaspeed3.
Ive got a log of me doing a 3rd to 4th gear WOT pull, once i shift into 4th the car bogs down. While im at steady speed, the car hiccups or Under slight acceleration i can feel the car jerking coming up in RPMs in between shifts during city driving. im not 100% sure what im looking at in the logs, however, what i observed is that my Relative Throttle Postition % drops as if i let up on the throttle during the WOT pulls. I had a known good Throttle body so i replaced that and it wasnt the problem. i did a smoke test to look for vacuum leaks and found none but didnt do a boost leak test. Can someone look at my Log if theyre able too and tell me what could be the issue and tell me what could be making it seem like im letting off throttle when im not? I appreciate your time!
Last edit: 2 years 8 months ago by Chad. Reason: Removed "Private" status.
2 years 8 months ago #64704
Replied by Chad on topic Whats making my relative throttle % come down?
Graph your O2 sensors during your WOT runs. ALL O2 sensors should go Full Rich during WOT. If your O2 sensor go Lean, then you have a fuel delivery issue.
- juergen.scholl
- Active partschanger
- Thank you received: 462
2 years 8 months ago - 2 years 8 months ago #64705
by juergen.scholl
Replied by juergen.scholl on topic Whats making my relative throttle % come down?
The change in throttle position may be an order of the pcm...
Are there any misfires and/or DTC's registered? Bogging under full load may point to an ignition issue.
Last edit: 2 years 8 months ago by juergen.scholl.
- LavishAutomotive
2 years 8 months ago - 2 years 8 months ago #64706
by LavishAutomotive
Replied by LavishAutomotive on topic Whats making my relative throttle % come down?
i greatly appreciate the responses. i will watch my o2 sensors, and i do not have any current, pending, or memory DTCs. I cant seem to be able to monitor misfire counts with my scan tool either. Its a Snap on scan tool and was able to with an 01 mercedes cl600 and 2019 rav4 but not on an 07 Mazda? must be not a supported PID or something. i have added a WOT log if someone is able to view it.
Last edit: 2 years 8 months ago by LavishAutomotive.
- Lupe
- Thank you received: 22
2 years 8 months ago #64707
by Lupe
Replied by Lupe on topic Whats making my relative throttle % come down?
does it rev up ok while in park or n ?
- LavishAutomotive
2 years 8 months ago #64708
by LavishAutomotive
Yes. It idles fine too. While at a steady speed, it also hiccups or feels like im getting nudged at probably 5-9% throttle.
Im wondering if its coil packs misfing but not severly enough to through a code?
- LavishAutomotive
2 years 8 months ago #64725
by LavishAutomotive
Hi, just a quick update. So im leaning towards my high pressure fuel pump reaching its max limit. I had vehicle detuned until i can get HPFP internals. After detuning, the HPFP is able to keep better.
Time to create page: 0.385 seconds
