01 Accord V6 3.0 P1399 Rough idle
  • Martin723
  • Martin723's Avatar Topic Author
2 years 8 months ago #64752 by Martin723
01 Accord V6 3.0 P1399 Rough idle was created by Martin723
I have a 2001 Accord V6 245k miles.  Iv been dealing with a misfire for a few weeks only when cold and accelerating.if I let the Engine idle until the fans come on it drives fine.so I usually start the car let it warm for 5min roll off my driveway and I soon I put to Drive and accelerate I lose power completely and starts sputtering few seconds laters engine takes off fast in the process of shift gears it keep doing it The strange thing is I get no Cel sometimesOnly code Iv gotten sometimes is P1399Original Catalytic converter. Could the converter be the issue?  Idle RPM 604/650ShortTrim -27.3 Longtrim 12.5 So far I replacedFuel injectorsSpark plugs ignition coilsidle air control valve TPS sensor & calibrated Map sensor fuel regulator and Fuel Damperupstream o2 sensor PVC valveEGR and clean passages No vacuum leaksGood compression Good fuel pressureReplaced fuel pump.Also have a video
2 years 8 months ago - 2 years 8 months ago #64761 by ksat22
Replied by ksat22 on topic 01 Accord V6 3.0 P1399 Rough idle
Your long term was +12%? If so, it seems strange your ST would be so negative at the same time, unless it was in response to a recent repair.
Regardless, your trim values are our of whack.
...... I just realized this is a V6. Are you showing 2 banks for fuel trims? If so, it'd be best to post both ST and both LT values
Last edit: 2 years 8 months ago by ksat22.
