P0087 00 fuel rail system pressure too low
- passdatvw
2 years 8 months ago #64787
by passdatvw
P0087 00 fuel rail system pressure too low was created by passdatvw
2013 VW passat 2.0 TDI CRKA having low fuel pressure issues. Starts after driving for approximately 16 miles. Loses power goes into limp mode with glow plug signal flashing. If I turn car off, and back on, will run fine for while then does same.
Have replaced fuel pressure sensor, fuel metering valve and fuel pressure regulator valve . No improvement.
Hpfp is clean as in no metal when taking metering valve off.
Just looking for some guidance, process to check/test different components to try and find problem . The lift pump I can hear when turning key on and I can hear it turn off when turning car key off.
I have vcds scanner tool. Thanks in advance.
- Lupe
- Thank you received: 22
2 years 8 months ago #64788
by Lupe
Replied by Lupe on topic P0087 00 fuel rail system pressure too low
most fuel presure codes are high p pump not working , check that, or by pass it. check and good luck
- passdatvw
2 years 7 months ago #64795
by passdatvw
Replied by passdatvw on topic P0087 00 fuel rail system pressure too low
Thanks. That's where I get lost a bit; how to go about checking...how to bypass?
- Lupe
2 years 7 months ago #64797
by Lupe
if this is your car you should get alldata for a month or year . there you can look that up , alot of wiring and infro . sorry i'm not familiar with your car but maybe some else in the forum is . good luck
- passdatvw
2 years 7 months ago #64829
by passdatvw
Thanks for information. As i'm looking into alldata, there are others like mitchel1 and such.I'm not so much looking for wiring info. I have concluded i need ti replace high fuel pressure pump. Do you think i should go with alldata or do you have other sources that may be better. I would prefer video how to's.
