2014 Dodge Grand Caravan SXT 3.6L Misfire on Cylinder 5
  • Kyddrivers
  • Kyddrivers's Avatar Topic Author
2 years 6 months ago #65390 by Kyddrivers
I have a '14 Grand Caravan with a 3.6L engine, and a misfire was reported on cylinder #5.  We have replaced all the plugs and the coil pack for #5.  We swapped the injectors around, but the misfire continued on #5.  What should my next steps be?
Thanks in advance!
2 years 6 months ago #65391 by Chad
I would grab a labscope and capture a Relative Compression waveform. If you don't have a scope, disable fuel and crank the engine. Listen to the cadence. Does it sound smooth and continuous? Or, is there a rhythmic pattern?
Can you feel/hear the misfire when the engine is running?
  • Kyddrivers
2 years 6 months ago #65395 by Kyddrivers
Yes, you can feel it misfiring and running rough. I will check and see if we have access to a scope.
Thanks
2 years 6 months ago #65396 by Noah
I'm with Chad, relative compression with a scope, or at least a traditional compression test with a gauge.
Not uncommon to have valve train issues on these...
2 years 6 months ago #65459 by Hardtopdr2
if no access to scope pull valve cover(s) and look at roller followers this is the common failure item for this engine platform.
  • Kyddrivers
2 years 5 months ago - 2 years 5 months ago #65631 by Kyddrivers
Thanks for the replies. We did a compression test, and Cylinder 5 is within 10% of another Cylinder tested.
Where to next?  Is this an electrical issue at Cylinder 5?  Is there an engine control module on this model?
Thank you in advance for your assistance!
Last edit: 2 years 5 months ago by Kyddrivers. Reason: additional questions
2 years 5 months ago #65632 by Noah
What was the compression for all six cylinders?
