2003 Chevy 4.3
  • bubbaf
  • bubbaf's Avatar Topic Author
2 years 4 months ago #65873 by bubbaf
2003 Chevy 4.3 was created by bubbaf
Hello my name is James I am trying to help a friend he swapped a 2003 4.3 that has two fuel lines to a 2007 4.3 that has 1 fuel line what does he need to change to make truck run? I'm thinking fuel rail and possible intake.
2 years 4 months ago - 2 years 4 months ago #65883 by Noah
Replied by Noah on topic 2003 Chevy 4.3
When interchanging engines from different years/generations etc., it is commonly accepted that the technician will use, from the engine that came out of the car, the intake manifold, fuel rail and injectors, engine harness at minimum, and be prepared to change the oil pan, valve covers, flywheel, engine mounts, accessory brackets or timing cover as needed.
I always start with both engines on the floor and don't install the new engine until it has all the necessary parts transferred over from the old engine.
Last edit: 2 years 4 months ago by Noah.
  • bubbaf
2 years 4 months ago #65890 by bubbaf
Replied by bubbaf on topic 2003 Chevy 4.3
What about fuel pump it still has 2 connections does he need to block it off
2 years 4 months ago #65893 by Noah
If he uses the intake manifold with the fuel rail and injectors that belong in the truck, there will be no reason to block off anything.
