02 Mazda 626 problems
- Ktipton388
2 years 4 months ago #65912
by Ktipton388
02 Mazda 626 problems was created by Ktipton388
I have a 2002 Mazda 626, 2.0l engine, All new sensors. New fuel pump, filter and injectors. New computer. All new sensors. New coil pack. Car cranks but wont start. Good fuel pressure. Good spark. Good compression. Fuel is getting to the fuel rail but that's it. The injectors are not spraying the fuel like they should. Noid light shows all injectors are working. I can't figure out the problem. It does not have the anti theft system . I've literally tried everything and have worked on this car for 3 years.
- FastestCaskets
2 years 4 months ago #65913
by FastestCaskets
Replied by FastestCaskets on topic 02 Mazda 626 problems
Does it run if you spray an alternative fuel in the intake?
- FastestCaskets
2 years 4 months ago #65914
by FastestCaskets
Also, how are you sure it doesn't have an immobilizer system?
There are a few diagrams available for the immobilizer on this car...
- Lupe
- Thank you received: 22
2 years 4 months ago #65931
by Lupe
Replied by Lupe on topic 02 Mazda 626 problems
did you check your fuel pre / regulator and crank sensor or rpm signal on dash while cranking
- stabbingju01.tipton
2 years 4 months ago #66034
by stabbingju01.tipton
Replied by stabbingju01.tipton on topic 02 Mazda 626 problems
I went to Mazda and they determined it didn’t by the vin
2 years 4 months ago #66035
Sensors are new and so is regulator, entire fuel system was replaced only thing that wasn’t is the fuel rail. Could the new ECM be causing this, it was suppose to be pre programmed but I guess there’s a chance it wasn’t right
2 years 4 months ago #66036
Yes I used starter fluid and it acts like it wants to start then
- David Leoncio
- Thank you received: 10
1 year 8 months ago #82958
by David Leoncio
Replied by David Leoncio on topic 02 Mazda 626 problems
I have one 626 with the same problem and end been the wrong new ckp sensor, it tooks me 4 months to realize it.
