2007 srt8 no start rpm signal
  • Topend
  • Topend's Avatar Topic Author
2 years 4 months ago #66037 by Topend
2007 srt8 no start rpm signal was created by Topend
Hi new here and just joined, been a mechanic for 35 years.
Have a 2007 srt8 jeep I did an engine rebuild on just rings bearings and crank cut and heads redone.
will not sync crank signal and watching it on scanners it goes to 142 rpm and drops off and will sometimes flicker again but not enough to start.
sensor has 5v and ground and signal back to pcm connection does what it should with a dvm.
I do not have a scope right now and will buy one if needed, but I don't see anything wrong with crank ring and did try 2 other sensors 1 factory and same luck.
is there anything that would shut the signal off at pcm?
all grounds even per manual are good and I even used cables for some extra.
Thanks in advance, it did run before was rebuilt just spun a bearing and now im struggling.
  • Topend
2 years 4 months ago #66038 by Topend
  • Topend
2 years 4 months ago #66039 by Topend
Replied by Topend on topic 2007 srt8 no start rpm signal
share.icloud.com/photos/021AiWEvoJgFOPWXBs_GdVXBw
And turning by hand I got nice signal cutoff with a dvm also
2 years 4 months ago #66040 by juergen.scholl
Replied by juergen.scholl on topic 2007 srt8 no start rpm signal
You got an actual fault code?
If it was a complaint about "sync" you may want to look at the cmp(s) as well.
Is spark and/or injector pulse present? I am sure you verified the physical timing....
  • Topend
2 years 4 months ago #66041 by Topend
No codes, yes physical timing was checked and also ran compression jic.
I did check cam sensor and wiring and even tried another jic but came up same.
I did not check injector pulse but when I did compression plugs where wet with fuel before i disabled fuel pressure to test.
  • Topend
2 years 4 months ago #66042 by Topend
My fear is the reluctor ring got switched somehow at machine shop. But I also do not know the sensitivity of the ring, my research shows that the cam sensor is not needed to start but the rpm signal failing is really getting me.
2 years 4 months ago #66043 by juergen.scholl
I would have bet that it needs a cam signal.....
Can you get your hands on a graphing scantool?
Verify that you get injection pulse indeed. Again, do you have spark? (Spark/injection would verify the pcm recognizes a valid rpm signal.)
Make sure there is no immobilizer issue present.
  • Topend
2 years 4 months ago #66044 by Topend
I do have injector pulse I also have normal spark at first start after battery unhooked for the night then upon a couple flashes the rpm signal drops and loses it.
  • Topend
2 years 4 months ago #66045 by Topend
share.icloud.com/photos/07233oHNns1WKnTyg7Dp5m3lQ
This is the graph that I got this am
2 years 4 months ago #66050 by juergen.scholl
If the injectors don't loose pulses then the rpm signal most likely is valid. I'm afraid you will have to up your tooling.
2 years 4 months ago #66057 by Noah
Replied by Noah on topic 2007 srt8 no start rpm signal
It is hard for me to see on the boroscope video capture, are there some teeth on the reluctor wheel that looks like they have contact marks on the face of them, or is this just light reflecting on the oil?
  • Topend
2 years 4 months ago #66061 by Topend
Sorry for the delay it is just light reflecting and I will say every time I take the crank sensor out it is soaked with oil film and it has me also thinking how strong is the signal to make it thru that.
I actually got out of most the automotive and went to heavy truck I build a lot of caterpillar engines, specialize in mechanical but I said to myself this thing really slings the oil. Lol
  • Topend
2 years 4 months ago #66062 by Topend
Thank you, what would you recommend tool wise and what I do next?
I have a laptop with a nexiq, I do mostly big diesel stuff now and sold my modis way back.
This kind of problem honestly is out of my norm I'm more mechanical or actual power and ground.
But I did this job to help a good friend and I'm sinking on it.
2 years 4 months ago - 2 years 4 months ago #66063 by juergen.scholl
I would start with verifying the integrity of the crank signal, with a scope. From there confirm ignition and injection pulses, again with a scope.Depending on the outcome a cam/crank relationship check may follow.
Last edit: 2 years 4 months ago by juergen.scholl.
2 years 4 months ago - 2 years 4 months ago #66068 by Noah
I agree with Jurgen. My first move would be to scope the cam and crank shaft sensors.
The scan data rpm dropping to zero while cranking is not normal in my opinion, but without seeing the signal generated by the CKP, it's difficult to tell why that is happening.
If you don't plan on jumping into the diag game with both feet, it might be more cost effective to hire this one out to a mobile specialist than to buy a scope kit and learn how to use it for this one problem. Of course, of you do want to spend money and time to learn scope use, then this is a good place to start.
Last edit: 2 years 4 months ago by Noah.
  • Topend
2 years 4 months ago #66080 by Topend
Thank you, so i searched and it seems the vantage pro would be about the best thing for me to use and play with because of the support here.
I found one local and it was 600 i offered 350 and am likely to pick it up on Tuesday.
Sadly it was a spouses that passed and she had a mechanic check it out and he said it works and is there but did not know the software off hand.
Does this sound sensible on this?
I only ask because it's not my specialty but have always learned learning it best to usually go with the most support vs best
2 years 4 months ago #66083 by Noah
Yes, that's a very good deal. The battery life likely will be less than great, but it's a very good tool.
There is an entire section on Scanner Danner Premium dedicated to training on that very tool, so I would say from that standpoint you are in a good position to learn while using it.
  • Topend
2 years 3 months ago #66144 by Topend
Finally got the vantage pro charged the battery and surprised it worked for now.
It seems it only goes to 2003 but here are pics of what I got I had to clean it was deff dusty so case is drying.
Would I be able to use the 2003 ram 5.7 to check this before updating and what's the best way to update this? Thank you
  • Topend
2 years 3 months ago #66145 by Topend
  • Topend
2 years 3 months ago #66146 by Topend
Time to create page: 0.360 seconds
