Scan Tool Stopped reading Mode 6 misfire data
- A Little ED
2 years 3 months ago #66186
by A Little ED
Scan Tool Stopped reading Mode 6 misfire data was created by A Little ED
Hello all,
I have a 2006 Ford 5.4L Triton and have been dealing with the misfire issues that are pretty common to this engine.
I bought an Autophix Bluetooth scanner a few years back that has worked great. It would tell me which cylinder was acting up under the mode 6 misfire data before a code was thrown so I could address it with a new coil.
I recently did a tune up where I disconnected the battery and removed the ECM for access. Now, the scan tool no longer reads misfire data and says "not supported" when I run the diagnostic.
I thought maybe my cheap scanner was to blame so I bought a BlueDRIVER but same thing. It's like the computer stopped reporting this data or something.
Any ideas why that might happen?
This thing misfires so often that i cant imagine having to guess which cylinder it is when it starts acting up.
Any help is appreciated.
2 years 3 months ago #66193
Replied by Chad on topic Scan Tool Stopped reading Mode 6 misfire data
If you disconnected the wiring harness from the ECM, make sure that no pins got bent when reconnecting.
- A Little ED
2 years 3 months ago #66197
by A Little ED
Replied by A Little ED on topic Scan Tool Stopped reading Mode 6 misfire data
I will check tonight. Thank you.
- A Little ED
2 years 3 months ago #66222
by A Little ED
Checked the ECM and all pins look good.
Is it possible the vehicle needs to be driven a certain amount of miles before the computer starts to read that data? Doesn't make any sense to me.
2 years 3 months ago #66258
It's possible that the misfire profile got reset when you disconnected the battery. If that's the case, you may not see the misfire counts populating in Mode $06. From Ford theory and operation:
"In the event of battery disconnection or loss of Keep Alive Memory the correction factors are lost and must be relearned."
"The correction factors are learned during closed-throttle, non-braking, de-fueled decelerations in the 60 to 40 mph range after exceeding 60 mph (likely to correspond to a freeway exit condition)."
However, I don't think that should stop the vehicle from reporting back about Mode $06 results if the scanner asks for them. As in, if you ask for Test ID $53 or $0B/0C results, the vehicle should report something back, regardless if there's no misfires or if the profile hasn't learned.
Do any of the other Mode $06 tests report back any results? Do the other OBD functions work correctly (readiness monitors, codes, Mode $09)?
Replied by Tyler on topic Scan Tool Stopped reading Mode 6 misfire data
