Fuel Rail
  • 1dmacho
  • 1dmacho's Avatar Topic Author
2 years 3 months ago #66422 by 1dmacho
Fuel Rail was created by 1dmacho
I have a 2007 Silverado Classic 1500 4.8L, replaced the injectors and #8 is leaking from the rail side. Removed and reseated. Still leaking. Should I just replace the rail or is there another way to stop the leak?
2 years 3 months ago #66437 by Chad
Replied by Chad on topic Fuel Rail
Have you done a close visual inspection of the injector, O-ring, and Rail cup? I would think that you should be able to see a defect that would allow leakage...a torn o-ring?,  a scratched/bent cup?, a cracked injector?
My aging eyes aren't what they used to be so I, sometimes, use an inspection camera for things like this.
2 years 3 months ago #66443 by Noah
Replied by Noah on topic Fuel Rail
My first thought is rolled o-ring. I still do it from time to time.o. Injectors and end up with a leak. A little smear of oil to lube the injector o-ring usually prevents this.
  • 1dmacho
2 years 3 months ago #66446 by 1dmacho
Replied by 1dmacho on topic Fuel Rail
Yes. That is exactly what I did. The injectors were new so it kind of threw me. So I pulled them out again change the O rings on the leaking one, a little oil and that fixed the leak. Thanks.
