2004 Chevy Venture 3.4 l v6 no crank no start after a crank no start situation
  • QuinnK
  • QuinnK's Avatar Topic Author
2 years 2 months ago #66568 by QuinnK
Hello forum, hello Danner,.  Mucho thanks in advance for all help through you tube videos, comments sections on those videos, detailing in detail is critical, and to the replys to this posts needs.  With all the fluffy out of the way.  Heres the facts and the stuff I've tried.
2004 Chevy Venture
Van ran and started
Drove it for 3 hours in the heat and up two large long inclines
Did not red line but got close
Long downhill and van cooled
Stopped and started again for a quick bevy
Drove another 30 min home
Gas was very low at this point
Van sat for two days
Started and moved van from one area to another on the property
​Then, crank, no start.
got gas twice, at least fifteen  dollars
battery was just replaced one month prior
No spark, crank
No crank no start
Reset anti theft, crank no start
Charging battery every day
Some bad fuses Pcm, ignition crank
No check engine light
Watched directional Danner vid on no check engi light on dash,
fixed some wires, cleaned a bunch of ground locs
Check cont on work
Checked for 5v on thermos
Performed variable bypass test on engine control mod, Danner style   t pin yellow, tap tap tappy, no happy
no crank no start
Reset pcm
Reset anti theft again
No crank no start
But the good new s is the fuse locs now working after  the whatever a while back
I'm thinking it's, but would rather not assume .  Please help if you made it this far, your awesome!
