U0100 2014 chevy traverse
  • Tymax30
  • Tymax30's Avatar Topic Author
2 years 2 months ago #66661 by Tymax30
U0100 2014 chevy traverse was created by Tymax30
I'm getting a u0100 after replacing the motor.i checked every fuse every relay and ground.to and from pcm and everything is seeing power that should and everything that should be grounded is showing ground I'm lost can some one please help thanks
2 years 2 months ago #66662 by Noah
Replied by Noah on topic U0100 2014 chevy traverse
It's important to know what module is setting the u1000 code, also which modules can communicate and which cannot.
I would probably start by checking the network resistance between pin 6 and pin 14 of the data link connector. Key off, (battery disconnected will definitely make sure there's no network activity to see the resistance measurement), with the network intact should report very close to 60ohms.
Just because I've had this problem with other GM products after dropping the engine, I'm going to hip shot a suggestion at you. Check that the EBCM (electronic brake control module or ABS module) connector is seated well.
Even if it looks okay, unlatch it and reconnect it and see if it restores communication to all the modules.
  • Tymax30
2 years 2 months ago #66671 by Tymax30
Replied by Tymax30 on topic U0100 2014 chevy traverse
Ok I will check that but I'm not communicating with the ecm and the tcm
  • Tymax30
2 years 2 months ago #66672 by Tymax30
Ok I did the test on pin 6 in 14 in I'm getting 120 ohms with the key off and battery un hooked
2 years 2 months ago #66673 by Monde
Replied by Monde on topic U0100 2014 chevy traverse
If the ECM and TCM are a combined controller, they might have one of the resistor. If they do, it may be open causing you to read 120 ohms instead of the 60 ohms. I don't know if there is a gateway or not. Check the Can Bus at the ECM and /or TCM to see if you still get the 120.
  • Tymax30
2 years 2 months ago #66674 by Tymax30
I'm not sure how to check that out do you no where to check at at the ecm
2 years 2 months ago #66675 by Monde
No. I don't have a wiring diagram. Usually, the CAN Bus wires are twisted.
2 years 2 months ago #66678 by Noah
Did you unplug and carefully reconnect the the ABS module connector?
The way the network is layed out there will be no communication with anything further out on the network.
The resistance measurement favors an open in the in the network, and that's usually where it happens after dropping the drivetrain out of these things. Seen it probably 6 times...
2 years 2 months ago #66681 by Tyler
Replied by Tyler on topic U0100 2014 chevy traverse
Second on the ABS module connector. Seen them not get fully latched more than once.
Also recheck X111 at the left front strut tower. It's part of the engine harness and gets unplugged if you took the harness out with the powertrain.
