Reduced engine power P2128
  • jay42782
  • jay42782's Avatar Topic Author
2 years 1 month ago #66896 by jay42782
Reduced engine power P2128 was created by jay42782
2008 avalanche 5.3 Lc9
APP Pedal Position Sensor 2 Circuit High Voltage code
Throttle Position sensor  1 and 2 sweep test voltage tests pass.Accelerator pedal position sensor 2 indicated position is stuck at 99% and Accelerator pedal position sensor 2 is stuck at 4.92 volts.  Any suggestions moving forward would be much appreciated
5v reference wires at the pedal connector check out ok
  • jay42782
2 years 1 month ago - 2 years 1 month ago #66897 by jay42782
Replied by jay42782 on topic Reduced engine power P2128
I'm guilty of a parts changer while I was waiting for my scanner to arrive. No change in values from the new accelerator pedal. Also all body/engine grounds/straps have been replaced and or checked out good. Relays and fuses also checked out ok
Last edit: 2 years 1 month ago by jay42782.
Time to create page: 0.263 seconds
