2013 chevrolet cruise dies
  • foos4me
  • foos4me's Avatar Topic Author
2 years 1 month ago #67128 by foos4me
2013 chevrolet cruise dies was created by foos4me
have a 2013 chev cruise that has a unique problem after running about 15 min it goes into a problem stalls loses injection pulse then when it wants to it works ok goes into reduced power with no dtcs shown has good fuel pressure   secondary ignition sparking when problem is present. just loses ground side pulse width  tested powers and grounds cleaned grounds ohmed inn 12.8   tried crank sensor and throttle body   thinking  pcm what's your 2 cents tia
2 years 1 month ago #67148 by Lupe
Replied by Lupe on topic 2013 chevrolet cruise dies
sounds like might be do to temperature , oil ,or speed sensor .with scanner check your pids when that happen if you can
The following user(s) said Thank You: foos4me
  • foos4me
2 years 2 weeks ago #67317 by foos4me
Replied by foos4me on topic 2013 chevrolet cruise dies
yes no. codes the only clue I have is on scanner pads it shows 5v ref in red autel scanner
