Misfire at high load in higher gears
  • coolbro50.d
  • coolbro50.d's Avatar Topic Author
2 years 1 week ago #67371 by coolbro50.d
Misfire at high load in higher gears was created by coolbro50.d
I drive a 2009 bmw 135i
N54 motor, 6 speed manual trans
Stock turbos
Upgraxed Chargepipe & BOV
Upgraxed FMIC
Downpipes
MHD 1+ tune
Ocassionally but not always, the car will misfire in higher gears under heavy load. Usually gears 3 and 4. Sometimes it will happen enough to throw codes for misfires and put me into limp. This log didn’t put me into limp, but definitely misfired a bunch.
Suspicions:
I’m still running stock coils and making 2x stock boost levels. Could be time to upgrade these.
Possible Low pressure fuel pump. Looking at rail pressures, they seem to be fluctuating down during high load. My HPFP was replaced under warranty years ago.
Injector. I don’t have the latest injectors from bmw, i have index 7s and 8s. The latest are 12s. Maybe i have a leaky injector or a clogged injector. Ocassionally when i go in my garage to start the car, i smell some gasoline. Maybe this is just some gas in the DPs? Idk.
2 years 1 week ago #67375 by Noah
Replied by Noah on topic Misfire at high load in higher gears
Often overlooked on higher boost engines is plug gap. They need to be pretty tight. Too large of a gap isn't any good under boost.
Just a thought
  • coolbro50.d
2 years 1 week ago #67391 by coolbro50.d
Replied by coolbro50.d on topic Misfire at high load in higher gears
The plugs are brand new. I’ll check the gap again.
