o2 sensor dugring WOT under load
  • Jan414
  • Jan414's Avatar Topic Author
2 years 3 days ago - 2 years 3 days ago #67447 by Jan414
o2 sensor dugring WOT under load was created by Jan414
Hi,
I was working on peugeot 206 with 1.4 16v engine. Customer consern was long crank when engine is cold. I test it and it was fine, but after 2 minutes of running it could just die. And there was no problem at all with restarting engine again. I noticed that it has "hole" in gas pedal. When i WOT during idle, it hasitate and even die. Sometimes it could backfire thru intake mainifold. OBD scan data show nothing worry about fuel trims were good. I took it on a road test and at WOT under load first o2 senor was switching rich lean rich lean, like normal crusing situation. I tested fuel pressure it was good. I plugged evap and crankcase breather hoes in case of false air. And checked intake mainifold with smoke machine, all good. I am wondering is this o2 reading normal ?
Last edit: 2 years 3 days ago by Jan414.
