2000 Lexus RX-300 p1346. This is the only code. OD is not working.
  • austinhunt9
  • austinhunt9's Avatar Topic Author
1 year 11 months ago #67517 by austinhunt9
2000 Lexus RX 300. Using a cheap scanner P1346 code which is VVT or timing belt issues. How can I determine whether the BBT solenoid or valve itself is bad?
  • austinhunt9
1 year 11 months ago #67518 by austinhunt9
Typo: VVT
1 year 11 months ago #67533 by Tyler
The most straightforward way to see if you're going towards a timing belt problem or a VVT problem is to clear the code and watch for when it resets.
Do this with the engine cold. Clear the code and start the engine. If the code comes back right away at idle, pull the upper timing cover and check belt timing.
If the code resets while driving, or at idle AFTER a test drive, go towards the VVT solenoid. These VVT solenoids almost always fail when the engine is warmed up, but rarely when cold.
