[FIXED] 2011 ford escape 4 cylinder charging system issues
- cheryl hartkorn
- Thank you received: 130
The only other thing I'd suggest is unplugging the alt field connector and getting the engine speed above 3K RPM. I know that'll be tough with the APP issue, but if you can get the alt to self excite, then it means you probably don't need one, and can go on with PCM replacement.
- cheryl hartkorn
- ScannerDanner
- Administrator
- Thank you received: 500
Tyler wrote: What are the voltage levels on the GENCOM and GENMON wires? I'd expect 0V on COM and around 10V on MON, even with no square wave activity. Mostly just trying to tell if the alternator regulator is still halfway alive. Who knows after a lightning strike, right? :silly:
Tyler, can you explain the self excite circuit of that alternator for me? I remember doing a case study with a GENCOM and GENMON test, but I'm drawing a blank offhand.
Which one of those two is the computer telling the alternator what to do and which one is the feedback circuit? Thanks!
Don't be a parts changer!
ScannerDanner wrote: Tyler, can you explain the self excite circuit of that alternator for me?
I'd love to! But, I honestly don't know how/why the regulator is wired this way. :blush: I just know that all the Ford PCM controlled alternators function this way, and even some of the internally regulated units.
Since the large B+ cable is the only electrical connection left after unplugging the regulator, I have to figure that the regulator is sourcing power from that cable, and somehow detecting an increase in rotor speed. Where's Andy when you need him? :lol:
The GENCOM is the command to the regulator, with square wave pulses at least once every five seconds, or during load changes. The MON is the feedback, 0-10V duty cycle. I wanted to see if the MON circuit still had 10V, as that voltage comes from the PCM.
cheryl wrote: Fixed. unplugged alternator as you suggested charged at 13.5 volts. put pcm in it programmed it and all is good now.
Sweet!
- ScannerDanner
- Administrator
So Ford systems that are using the GENCOM and GENMON alternators. For a no charge event, unplug the alternator connector and hold over 3000. IF it starts to charge = alternator is fine, there is a control issue with the PCM or wiring in between.
Does that sound right?
Thanks buddy.
Thanks buddy.
Yep, you got it.
You'll love the next step. The OE flow chart then recommends shorting GENCOM and GENMON together, starting the engine, and looking at the associated scan data PIDs to match. If they do, then the wiring is good, or so I'm told. :lol: I found this the other day while poking around Mitchell, just gotta get the Escape away from my wife so I can try it.
- cheryl hartkorn
- ScannerDanner
- Administrator
Thanks buddy.
Yep, you got it.Of course, getting to the connector is easier on some than others - like a V6 Ford Escape.
You know me well Tyler
And nice job cheryl hartkorn!
cheryl hartkorn wrote: to answer your question the gen mon did have 12 volts unplugged. as for other surprises yea it doesnt have turn signals or headlights
Psh, headlights? Turn signals? Who needs 'em! :lol:
(Sounds like the BCM is cooked?)
