Engine rpm and injector pulse width fluctuate at Idle occasionally
  • karim
  • karim's Avatar Topic Author
9 years 2 months ago #12143 by karim
Dears,
If the engine rpm and injector pulse width fluctuate at idle, what could cause this? a little shaking noticed on my Toyota Avalon 2012
Thank you
9 years 2 months ago #12144 by Andy.MacFadyen
I will move this into the correct section
The following user(s) said Thank You: karim
9 years 2 months ago #12146 by Andy.MacFadyen
The injector pulse width will continuously change as the air/fuel ratio switches around the ideal stoichiometric ratio but a lot of variation coupled with the rpm rising and falling (old school mechanics called this "hunting" ) would make look first for a vacuum leak.
Hunting - rising and falling idle speed is often associated with vacuum leaks.
I would look at the fuel total fuel trim short term and long term for each bank at idle and around 2000 to 2500 RPM.
If the fuel trims are addding fuel at idle and are near normal at higher RPM it points to a vacuum leak.
